Hello, all. I just moved from Win10 to Win11 on a new pc. I have a lot user-defined genres, and I was wondering if there’s a way to transfer them fron the old MP3Tag application into the new. Are they stored in a certain file in the directory?
The easiest way would be to import the configuration from the other system:
For the user-defined Genres you can also use Export and Import:
