Installation & Backup
Mp3tag in the PortableApps.com Format
Portable App request
Location of MTE files
Actions are not being saved (or working)
Suggestion: Portable configuration
Create backup of Actions
transfer settings to a new installation?
restore mp3tag configuration file/zip??? how???
Feature Request - iTunes Tag Source?
Where are the Settings Stored? In Case of Reinstal
Where I export the configuration files created by MP3TAG Free version
Lost all my Filters
OS X version ... settings, etc.
Cover-only import
Sharing settings among different profiles?
Mp3tag v2.38 released
3.02 Install problems
Import Settings
[X] Runtime error closing Mp3tag
mp3tag on windows 7
What files do I need to keep my settings in XP upgrading to 10?
Windows Won't Let Me Unstall Old MP3Tag to Update
Transfer from old hard drive
2 Fragen - Konfiguration sichern / Wo sind meine Daten geblieben
[Not Working] Spotify, Gracenote and Saavn WebSource Scripts
Save configuration subfolders
Tag sources disabled after upgrade to 2.6x
Where are new Tag Panel values stored?
mp3tag wirklich "portable machen"
Export / Backup Actions and Import to another PC
Mp3Tag auf dem USB Stick
Run multiple instances possible?
Mp3tag v2.47 released
Genre category drop-down
Portable install method
How to move the "Settings" folder to a subfolder of the Mp3tag install directory?
[X] V2.54 On read-only drive, portable install gives Access denied on exit
Save/backup format strings
Find and Replace list of Album tags
Cloning a fairly complex mp3tag configuration
Error connecting to server: http//www.discogs.com
New Web Source in Wine under OS X
Unzipped Action Groups into the right folder, but they're not showing up
cannot locate profile folder for discogs source mod
Problem using v2.78 on my Windows 7 PC.
Wann wird eine portable Version angeboten?
Action Group.
Inport settings
Export more info
Loss of settings after closing mp3 tag
[X] folder dialogs freezing
Desktop configuration copy to portable
Actions to convert tags to/from greeklish
Update - long period in between 2.86 -> 3.01
Just installed a script and it's not showing up under Tag Sources
[WS] Discogs (pone mod)
How do I remove Discogs
Cyrilic to Latin transliteration
Mp3tag Kontext Menü Eintrag feht neuerdings
Location of user-defined genre
Can I keep my settings when updating to a new version?
Yes, you can install a new version over an already installed version. The installation program will keep/upgrade your settings.
Can I backup my settings or use them on a different computer?
Yes,
  1. To backup your settings, please choose File → Save configuration.
  2. To restore the backup, you have to unzip the backup archive to the folder that opens when you choose File → Open configuration folder. Close Mp3tag to ensure that all files can be written.
For a Standard installation, the configuration folder is at %APPDATA%\Mp3tag which usually expands to C:\Users\<username>\AppData\Roaming\Mp3tag
For a Portable installation, the program directory is used to store the settings.
For a Microsoft Store installation, the configuration folder is at C:\Users\<Your Name>\AppData\Local\Packages\35795FlorianHeidenreich.Mp3tag_rf0p6xgxmspcc\LocalCache\Roaming\Mp3tag\
How to build a portable installation of Mp3tag? (e.g. on a USB stick)
You can install Mp3tag in portable mode.
Cannot write configuration file
If you're getting the error message Cannot write configuration file when closing Mp3tag, it's most likely a file permissions issue.
This can happen if you recently updated your Windows version or moved data from one computer to another. In this case, the file permissions sometimes reference Windows user accounts that do not exist on the updated computer or are not the one which you're currently using.
To resolve this, the file permissions need to be adjusted. How to do this is described in the following steps
  1. Open Windows Explorer and enter %APPDATA% to the address bar
  2. Locate the folder Mp3tag, right-click and choose Properties from the context menu
  3. Open the Security tab which allows to view the permissions of this folder
  4. Choose Edit to change permissions of this folder
  5. In case your user name is not listed in the list of permissions, choose Add and provide your user name and make sure that you allow Full control
  6. Make sure that your user account has full control to this folder
Right-click context menu is missing on Windows 11
Assuming you've already restarted explorer.exe via the right-click context menu in Task Manager (or have rebooted Windows), this is happening sometimes on Windows 11 for reasons which I still trying to find out.
What might help in those cases and when the classic context menu is preferred, is to manually register the shell extension from a command prompt with admin rights:
cd <path to Mp3tag installation>
regsvr32 Mp3tagShell.dll
Context menu disappeared in ver 3.23 on Win11
V3.24 does not install context menu item
Context menu app not in the right context menu
Context menu installation error
Windows 11 on ARM: no entry in explorer context menu
Absence of MP3Tag line in the Windows context menu
MP3Tag not appearing in context menu
Verzeichnis im Explorer öffnen
Not appearing in context menu on new install
Shell Integration in Windows 11 LTSC
Staging Sparse Package failed is back
Bring Mp3 tag option in old context menu of file explorer
On Win 11 Pro the mp3tag context menu vanished after the last update
MP3Tag missing from Windows Right click drop down box...again
Windows explorer extension is no longer working after Win 11 PRO update in 3.30 release
Explorer integration doesn't work anymore?
Mp3tag missing in Total commander context menu: use "sendto" instead
Context menu option is missing on Windows 11 Home"
Mp3tag not showing up in file manager context menu anymore?
Where did MP3Tag explorer context menu go?
Kontextmenü fehlt unter Windows 11
MP3 Tag no longer shows up in Windows 11 Right Click Explorer menu
Disappeared from Windows Explorer context menu
3.37 schreibt keinen Explorer-Kontextmenü-Eintrag mehr
MP3Tag Not Showing In Windows Context Menu
Why I can't find the MP3TAG shortcut in the FILE EXPLORER
V3.33.1 - right click context menu was removed
Meine Tag Quelle zu https://legacy.hitparade.ch funktioniert seit neustem nicht mehr
Explorer shell context no longer there
