Lyrics in FLAC?
So when I use my android applications such as PowerAmp and various other players, they all recognize the lyrics to all my mp3/m4a files except the flac files.
I add lyrics to 'UNSYNCED LYRICS' but the flac files never show the lyrics. How can I allow it to display lyrics?
This is my tagging setup, maybe something here needs to be changed?
So I found my solution. IT turns out, it's very simple.
Here is what I did for others that might look for answer in the future.
Options -> Tag Panel -> Add field... -> LYRICS
and / or
right-click on a column header -> Customize columns... -> New configuration ...
Thanks for the help everyone.
