MCool is a very lite player, which can display also the external *.lrc lyrics files as karaoke when playing any audio, which has the lyrics external *.lrc file. To make it as your default player without changing your actual default player (for example: the Windows Media Player), open MP3Tag and select:
Tools ►Options and click New:
Name: Play with MCool Player
Path: C:\Program Files\MCoolPlayer\mcool.exe
Parameter: "%_folderpath%%_filename_ext%"
for all selected files
