Moving part of TITLE to GENRE
Hello
I would like to know, if it is possible to create an action group that would do this:
1] look at the end of TITLE tag
2] if there is a "##something" or "## something" or "0000", move it to the beginning of GENRE tag
3] look again at the end of TITLE tag
4] if there is a "##something" or "## something", move it to the beginning of GENRE tag; with the addition of two pauses after it
5] stop looking as soon as the end of the title tag runs out of the "##" indicator
6] rearrange numerically / alphabetically the GENRE tag
7] remove repeated stuff
Examples
TITLE tag: Make Me... Make You! {2012 Mix} [MEE]    ##55 ## 02 ##03    ##01    ##VILLAGE    ## CITY  ##77   ##ACTION  ## BATTLE  ##ZZZZZZZZZ ## DESERT    ##66
[is split into]
GENRE tag: ##01  ##02  ##03  ##ACTION  ##BATTLE  ##CITY  ##DESERT  ###VILLAGE  #ZZZZZZZZZ  ##55  ##66  ##77
TITLE tag: Make Me... Make You! (Instrumental) {DJ XXX Remix}   0000
[is split into]
GENRE tag: 0000
TITLE tag: Make Me... Make You; PART 2 {Live 2000}##77 ## 33       ## 66      ## 55## 44
[is split into]
GENRE tag: ##33  ##44  ##55  ##66  ##77
TITLE tag: Make Me... Make You; PART 3## 33  ## 66  ##33    ##33  ## 66
[is split into]
GENRE tag: ##33  ##66
So please note that the there could be a total chaos, but the "##" / "## " indicates always a new separate value, and the must-be-order is:
numbers from 01 to 49 >>> words >>> numbers from 50 to 99
I think that the first 5 steps can be dealt with like this:
Copy all of the TITLE to GENRE
Apply an action of the type "Replace with regular expression to GENRE
Search string: ^(.) (#.)$
Replace string: $2
This removes the text in front of the first ##.
Do the same with TITLE only with
Replace string: $1
Now you have all the raw data in the fields. Now have fun with the sorting.
Unfortunately, it removes everything placed before the last "##"
That seems to do nothing
The sorting could be done quite easily [although in long steps]
A] Remove all the "##" [which leaves numbers in format >>00<<]
B] Replace words with numbers [in format >>00<<]
C] Leave only one instance of each number [because I need to remove the doubled and tripled ones]
D] Rearrange numbers in order [sort them out]
E] Put two pauses after each number
F] Change [specified] numbers back to words
G] Put back "##" in front of the numbers
H] Put back "##" in front of the words
I] Remove unnecessary pauses
So, I would like to ask for codes for point C, D and E
Also, I'm afraid that step D could mess things up [because it could possibly turn for example "99 01" into "0199" instead of "01 99"]
And please note, that all the time I'm using the "##" [double hashtag] as a marker and not "#" [single one]; becasue I already use a single # chacacter [in TITLE tag for different purposes]
Shame this, really. Sorry.
If it is always the ## that separates TITLE from GENRE, you could apply an action of the type
"Guess value (Import tag field)" for TITLE
Guessing pattern: %title% #%genre%
you loose the leading #.
I did some test and thinking about that whole guessing pattern and came with solution with workaround / fail-safes
But I still don't know how to simply sort numbers in order and put two pauses after each number [step D and E]
So, does any one now how to sort two digit numbers in an ascending matter?
For example:
BEFORE
01 10 22 21 33 99
AFTER
01 10 21 22 33 99
BEFORE
99 01 10 22 21 33
AFTER
01 10 21 22 33 99
BEFORE
10 99 01 22 33 21
AFTER
01 10 21 22 33 99
If you are looking for a built in function: hard luck, there is none.
Also, you cannot use any nested loops to treat a string.
You could export the field to a text file,
use the command shell function "sort"
let "sort" create an output file that you then import back into the tag.
To see what "sort" can do, open a command shell window and type in: help sort
AFAIU sort needs one sort item per line
Mp3tag has no sort function to be used within formatstring.
You may have a look there ...
Feature request: Import tags from clipboard
... maybe you can adapt it to your needs.
DD.20150616.2156.CEST
Unfortunately that's just to much effort / steps; beause I will need this to be done on 18000 files
And after a couple of weeks / months, I will repeat the whole operation, with even more files
That looks adaptable to my needs
But, aside from possible re-designing the system, it would still require physically going [switching] to another window with different program and doing there some clicking? If yes then I will have to do this sorting manually
As long as I will do it on a big set of files and have all the data in the same format [with numbers], I could to this quite efficient; aside from course occasionally missing some errors, which can be possibly taken care of during the next evaluation
And the bigger the set the better [to some point I imagine...], because it will be somewhat easy to spot an error like this
##01  ##02  ##03  ##44  ##59  ##99  ##90
if it is between tens of looking the same correct ones
##01  ##02  ##03  ##44  ##59  ##60  ##90  ##99
##01  ##02  ##03  ##44  ##59  ##60  ##99
I just need enough correct cases, so that errors will "pop out" while scrolling the view down
[I've already tried to the the first evaluation and in mixed system, with words between bumbers, it looks like chaos; I just stopped after first few screens]
zerow, I do not understand what you are telling me, ...
therefore I made an example action group script ...
to demonstrate how to sort number strings in the range from '01' to '99'.
Begin Action Group Test2015#20150617.Example.Sort.01to99
Action #1
Actiontype 5: Format value
Field ______: LIST_CURRENT
Formatstring: '04|21|69|99|17|01|38|78'
Action #2
Field ______: LIST_ORDERED
Formatstring: '01|02|03|04|05|06|07|08|09|10|11|12|13|14|15|16|17|18|19|20|
21|22|23|24|25|26|27|28|29|30|31|32|33|34|35|36|37|38|39|40|
41|42|43|44|45|46|47|48|49|50|51|52|53|54|55|56|57|58|59|60|
61|62|63|64|65|66|67|68|69|70|71|72|73|74|75|76|77|78|79|80|
81|82|83|84|85|86|87|88|89|90|91|92|93|94|95|96|97|98|99'
Action #3
Field ______: LIST_RESULT
Formatstring: $regexp($regexp($regexp(%LIST_ORDERED%,$regexp(%LIST_ORDERED%,'(?>('%LIST_CURRENT%'))',),),'|+','|'),'|$',)
End Action Group Test2015#20150617.Example.Sort.01to99 (3 Actions)
... which gives ...
LIST_RESULT = 01|04|17|21|38|69|78|99
Test2015_20150617.Example.Sort.01to99.mta (535 Bytes)
DD.20150617.1836.CEST
Note: Regular expression has been changed ... see there ...
DD.20150626.1116.CEST
I have run this action group on a field with value
And it stayed the same; nothing changed
Aside from that, my question is: is this is going to work only, if I predefine [write down to that action group] a separate entry [action] for every possible combination of errors?
For example a common mistake will be
##01  ##01  ##02
But also there can be something like
##01  ##01  ##01  ##02
##01  ##99  ##01  ##02
##99  ##01  ##02
##99  ##01  ##99  ##02
##02  ##01  ##02
Putting all possible cases is just impossible for a human being
Please try again.
At my side there is no problem to get ...
LIST_OUT=01|04|17|21|38|69|78|99
from ...
LIST_IN=04|21|69|99|17|01|38|78
LIST_IN=04|21|69|99|17|17|01|38|78|21
LIST_IN=78|04|04|04|21|69|99|99|17|17|01|38|78|21|78
DD.20150622.0943.CEST
I've read the code and thought about what is suppose to happen and finally understood it [but not how it is happening]; and so I see that it works now
And now I have the right tool and the knowledge how to adapt it to my needs. I've already made some changes in it. But to make the whole operation simpler [with less steps, which will come in handy in the future in case of making any changes to the naming structure] I've tried to replace the
|sign used by you with the indicators used by me, in form of
And with such change, the code stops to work. Is there some problem with using hashtags? Or a change like that shouldn't be a problem and I just messed up something?
Also: why does the first number [in my unsorted string of numbers] can't have the indicator? I have putted it to the front of LIST_ORDERED, but it didn't help
Note: The pipe symbol or vertical bar "|" has the meaning of "alternation" resp. "or", ...
and is used within the regular expression to separate alternative values.
'01' or '02' or '03' ==> '01|02|03'
See also:
http://www.regular-expressions.info/alternation.html
I don't know for sure, but you may try for your case ...
'##01|##02|##03'
... or ...
'##(01|02|03)'
DD.20150624.2020.CEST
Those two suggestions didn't work, but I've managed in some other way
Here is my action group:
1] Guess values %GENRE%: ##%GENRE%
2] Replace "GENRE": "##" -> |
3] Replace "GENRE": "  " -> ""
4] Format value "GENRE_ORDER": '00|01|02|03|04|05|06|07|08|09|10|11|12|13|14|15|16|17|18|19|20|21|22|23|24|2
5|26|27|28|29|30|31|32|33|34|35|36|37|38|39|40|41|42|43|44|45|46|47|48|49|TRIBAL
UNDERWATER|VILLAGE|WASTELAND|WATER|60|61|62|63|64|65|66|67|68|69|70|71|72|73|74|
7
5|76|77|78|79|80|81|82|83|84|85|86|87|88|89|90|91|92|93|94|95|96|97|98|99|9X'
5] Format value "GENRE": $regexp($regexp($regexp(%GENRE_ORDER%,$regexp(%GENRE_ORDER%,'(?>('%GENRE%'))',),),'\|+','|'),'\|$',)
6] Replace "GENRE": "|" -> "  ##"
7] Format value "GENRE": $trim(%GENRE%)
8] Format value "GENRE": ##%GENRE%
It works if run it on a GENRE tag that has values in format
##00  ##00  ##AAAAAAA  ##00  ##BBB
[two hastags + two digit number or predifined capitalized word + two pauses]
But:
A] What is the code for making any number of spaces into only two spaces, including in the middle of a tag? Or what is the code for making 3 or more spaces into two spaces? Right now I use [before I run this action group that we are speaking of in this post] many many [just for sure] instances of
Replace "GENRE": "   " -> "  "
for achieving my format
B] This code has a big issue. If you run it on
##9X  ##WATER  ##00  ##UNDERWATER  ##50  ##VILLAGE
it will give you a proper
##00  ##UNDERWATER  ##VILLAGE  ##WATER  ##50  ##9X
But if you run it on
##9X  ##WATER  ##00  ##50  ##VILLAGE
you will get a reasult with a wrongly doubled value
##00  ##WATER  ##VILLAGE  ##WATER  ##50  ##9X
just because on the list of words [within this list of those 00-99 numbers] there is "UNDERWATER" and "WATER". I could work around this problem by temporary changing words to some additional numbers / codes [like X00, X01, X03], but as the word list is a work in progress, I would rather not have to [remember to make additional changes in this GENRE rearranging action group every time I will add new words or change the old ones]
TEST_SPACES <== 'xx xx xx xx xx xx xx xx xx xx' TEST_RESULT <== $regexp(%TEST_SPACES%,' +',' ') TEST_RESULT = 'xx xx xx xx xx xx xx xx xx xx'
DD.20150625.0709.CEST
I assume a failure in your test environment, because it works as designed.
LIST_IN   <== '01|09|WATER|04|VILLAGE|06|UNDERWATER|08|03|02|10'
LIST_SORT <== '01|02|03|VILLAGE|04|05|06|WATER|07|08|UNDERWATER|09|10'
LIST_OUT  <== $regexp(
               $regexp(
                $regexp(%LIST_SORT%,
                 $regexp(%LIST_SORT%,'(?>('%LIST_IN%'))',)
LIST OUT    = 01|02|03|VILLAGE|04|06|WATER|08|UNDERWATER|09|10
DD.20150625.0757.CEST
Yes, that takes makes my double spaced format with just one action, for any number od spaces
Thank you for helping me in getting rid of
Which removed only up to 11 unnecessary spaces and also changed one into two
So what you are saying is, I have to do a workaround: change all the words [or at least cases like WATER / UNDERWATER] to unique set of characters; and run the code in version including those temporary unique changes in the order list?
Because double WATER is immanent and is not to be viewed as an error?
Well, there is a problem within the regular expression, which has not be shown, when using numerical string values in the range from '01' to '99', but might coming up for strings like '101' .
Other text strings like 'WATER' and 'WATERFALL' will show the same problem.
There is no problem for 'WATER' and 'UNDERWATER'.
The failure was in the regular expression, which has evaluated the leading string fragment but not an entire word. Following example now evaluates a word for the comparing.
LIST_IN   <== '111|101|01|WATER|WATERFALL|04|VILLAGE|06|UNDERWATER|03|02|10|11'
LIST_SORT <== '01|02|03|04|05|06|07|08|09|10|11|101|111|UNDERWATER|VILLAGE|WATER|WATERFALL'
               $regexp(
                        $regexp(%LIST_SORT%,'(?>\b('%LIST_IN%')\b)',)
LIST OUT = 01|02|03|04|06|10|11|101|111|UNDERWATER|VILLAGE|WATER|WATERFALL
DD.20150626.1123.CEST
