Mp3tag v3.13 released
I've just released Mp3tag v3.13 and wanted to outline some of the new features and changes:
Revised Tag Sources Confirmation Dialog
I’ve completely (almost!) revised the confirmation dialog that shows the metadata result when importing via any of the Tag Sources (e.g., Discogs or MusicBrainz). It now allows for selecting which fields to import via checkboxes, also for the cover, and provides a better overview of track-specific and album-specific metadata.
Revised Documentation
I’ve rewritten and updated most of the existing help files and published them at https://docs.mp3tag.de
Revised Tag Sources
I’ve also revised the Tag Sources for Discogs and MusicBrainz, which now use CATALOGNUMBER for the catalog number. The MusicBrainz Tag Source now also imports BARCODE and ISRC — all of which can be easily disabled by the new methods I’ve outlined above.
Improved Sorting Performance
Sorting the File List is now significantly faster. It's most notably for large libraries, but also much snappier when you're sorting smaller sets of files.
Download the new version
https://www.mp3tag.de/en/download.html
Support my work as an Indie Developer
https://www.mp3tag.de/en/donations.html
As always, thank you for reading, your interest and your support.
Enjoy and take care
— Florian
Additional Features and Fixes
New Features
- added option to don't show the message that asks for keeping existing cover art again at Tag Sources confirmation dialog. (#17642, #44589)
- added support for
BARCODE,CATALOGNUMBER,ISRC, andMUSICBRAINZ_ALBUMRELEASECOUNTRYto MusicBrainz tag source. - added
%_cover_description%information field. (#55952)
Changes
- added confirmation question on choosing converter, actions, or extended tags if the Tag Panel contains unsaved changes and auto-saving is not enabled. (#56065)
- added confirmation question on editing via File List if the Tag Panel contains unsaved changes and auto-saving is not enabled. (#55633)
- added error reporting to formatting string language. (#46638)
- added internal mapping for
MUSICBRAINZ_TRACKIDfield. (#44062) - added reporting of unsupported or corrupted file structure as error to 'Tag' column.
- revised Tag Sources confirmation dialog to allow selection of fields to import. (#54105, #56398)
- revised Tag Sources confirmation dialog to distinguish between track-specific and common metadata.
- removed Utils > Compilation option from Tag Sources confirmation dialog which can be realized using an action Guess Values.
- added support to enable and disable import of cover art via checkbox at Tag Sources confirmation dialog.
- added support for editing track-specific and common metadata at Tag Sources confirmation dialog.
- added support for internal resizing via horizontal splitter at Tag Sources confirmation dialog. (#56667, #56689)
- added support for multi-value MP4 fields written as multiple
dataatoms. (#56138) - added support for using online documentation as internal help.
- added workaround for missing padding bytes for INFO subchunks in WAV and AIF. (#56080)
- added workaround for MP4 data atoms with superfluous trailing null byte. (#56526)
- automatically removing control characters \n \r \t when renaming files and folders.
- changed Discogs tag sources to use
CATALOGNUMBERinstead ofCATALOGIDto improve compatibility with other software. - ensured that characters with accents or umlauts are using the Unicode Normalization Form C when querying Tag Sources.
- extended
$validate()to replace control characters \n \r \t. - improved sorting performance for large libraries. (#56739)
- updated list of default freedb servers to remove invalid servers.
- updated Brazilian Portuguese, Catalan, Chinese-CN, Czech, French, Hebrew, Italian, Slovak, Spanish, and Ukrainian translation.
Bug Fixes
- apostroph character in export file path caused syntax error. (#55431)
- configuration files with very long filenames produce runtime error when exporting settings.
- copying or moving files resulted in inconsistent display of data if overwrite or keep both is used. (#56008)
- cuesheets encoded with UTF-8 BOM were written with ANSI encoding. (#13487)
- empty file name at export dialog also disabled edit, duplicate, and remove buttons.
- freedb web search via gnudb.org wasn't working anymore.
- playlist-specific placeholders were reset when loading new files or directories. (#56439)
- pseudorandom number generator used by
$rand()was not seeded correctly in all cases. (#56760) - taskbar icon was missing when starting from File Explorer shell extension under Windows 11 using Standard installation. (#54913, #55081, #55645)
