Mp3Tag Web Sources Script Language for Notpad++
Here is a xml file which contains a User Defined Language for the freeware text editor Notepad++.
It highlights the syntax of .src files so it's easier to edit them and you will spot error faster.
I found it somewhere here in the forum some time ago and have made some modifications to it over the time.
Mp3Tag_Web_Sources_Language_for_NotpadPlusPlus.zip (970 Bytes)
