Mp3tag will not load or import into its window any song files
Program is having a melt down if I highlight any number of files even just 1 file and drag and drop it into Mp3tag it does not load, If I use the change directory option and click a song file and open it shows a status bar as if it is performing but the status bar closes and the Mp3tag window remains empty
How many files are indicated in the status bar to have been loaded?
Sounds very similar to this thread. Make sure the filter is cleared. Even a single blank space can make a big impact.
