MP3Tag with command line shell?
Hello,
Is it possible to use MP3Tag only on the command line with windows shell?
for example to remove tags from an mp3 ?
tk's for help
RS
The answer is still the same: No.
Despite its misleading name, EXIFtool might be what you are looking for. I believe FFmpeg can be used for some basic CLI tag editing as well.
@Crissov Are you sure that EXIFtool can WRITE ID3 tags? As far as I know, it can READ it, but not write it:
The developer Phil Harvey wrote some years ago:
I actually started writing an ID3 writer in 2006, but got discouraged because it turned out to be a more difficult task than I thought. A large part of the problem is that the ID3 specification is crap. So unfortunately adding ID3 write support isn't something that will happen in the foreseeable future.
I'm not sure, if this still is valid.
You are right, I totally forgot about that.
