Though I have been using the tool for quite some years now, I would like to start by admitting that I am a complete newbie as regards using the syntaxes that are used in this software.
I have a specific issue with regard to file renaming. I have a lot of music files across 10 flash drives and organised by Album, because my Fiat Blue & Me audio system allows me that luxury.
However, I have since past two years been travelling on international projects and hence no car!!
I do have with me something called a Sound Micro from Nakamichi which allows me to use flash drives to listen to music. The player has its own complicated way of programming music which I want to avoid as it would be cumbersome.
I suddenly recalled MP3Tag helped me a lot a few years ago and I had completely forgotten about it. I know it can do the job but my limited knowledge on using it restricts me.
Each flash drive has multiple albums and the tracks are numbered per album, meaning Album A has 10 tracks and they are numbered (as you see under the # column of Windows Explorer) 1 to 10, then Album 2 has 20 songs and they are numbered 1-20 and so on.
What I would like to do is to first sort ALL songs by Album (in Windows Explorer) and then rename them such that the album-wise sequence remains intact. So the songs will therefore have a three digit number at the beginning, e.g. 023 Candle in the Wind, so that when I plug in the flash drive into the Nakamichi, the songs start playing by sequential numbering order rather than alphabetical order like it is doing now (and thus playing tracks from different albums in alphabetical sequence).
If I could get some help on how to do it using Filename - Filename conversion, I shall be grateful.
Usually, any kind of problems with players applying their own strangely sorted order is due to missing data in the fields ALBUMARTIST, ARTIST, ALBUM, TITLE, TRACK.
So, are these fields filled?
The next thing that would be interesting: By what criteria does the player sort?
The filename, because the tag fields are empty?
What happens once you filled the tag fields?
Does it still only use the filename? Or does it use the field TITLE?
Finally, I doubt that the function Convert>Filename-Filename would be the best function.
I would think that Convert>tag-filename is better even if the format string would only be %_counter% _ %_filename%
Well I should have said in the beginning itself, my mistake, that all the songs have those fields fully filled in, i.e. album, artist, title, track and sequence.
As regards the criteria of sorting used by the player, honestly I don't think the player has a lot of intelligence built in, except for a programming functionality of max 20. So what it means is that it plays using alphabetic or numeric order.
Since the files are already filled with tags, and the player doesn't respond to them, I can safely assume that it can only play in the order the track names are, i.e. alphabetical order.
Many thanks for the help. It worked perfectly as far as the tagging was concerned.
But then the next thing was to see how the player responded. Mine is a small machine called SoundMicro from Nakamichi - nothing special except the sound quality being superb. Controls are at best basic or in a few cases - such as USB playback - less than basic.
A really weird thing is happening here. The player doesn’t bother about the order that I created by renaming the files as above. Rather it chose to play a different song, that too with a message - NO ID3. When I checked back the USB on my computer, I couldn’t see any tagging problem or missing tags.
I don’t understand the syntax of the tagging and as to what really is the player seeking, so I’m again stuck there.
Another thing I noticed in the manual, where it says that only FAT 16 and FAT 32 compatible.
Well I don’t understand those terms but what’s surprising that only one song comes up As. NO ID3. All the other songs from the same album and other albums are showing alright. But yes, the sequence of playing isn’t helping.
What would you suggest doing in this case? I’m truly sorry to bother you.
Again: see the player's documentation or try some reverse engineering.
Which are?
When you drag and drop files, you usually have the mouse hovering over a particular file. Is this file that does not fit in the expected order?
And a personal note: I would like to point out that it is you who has the problem, not me. So it would be in your own interest to supply as much information as possible - unless you don't care any more and you either can live with the way it is or have solved the reason why you posted.
So anwers like
or
Do not help to narrow it down.
Your initial statement
points into a direction where the files may be
but this says hardly anything about the tags.
Please check the files with the utilities linked here:
