I checked www and here but did not find the information.
I only need the setting/table/query where standard genre are saved in Windows (see pic). What I found out is that there must be a standard in OS regarding existong genres from files...
BR
gerste
It's not a standard that is enforced by the operating system, but instead a standardized list of ID3v1 genres which is hard-coded into the different applications.
You can, however, completely disable that list at "Options > Genres" and add you own user-defined genres which will the appear on the list.
Kind regards
— Florian
Yes, and the table is standardized, see e.g. https://en.wikipedia.org/wiki/ID3 and scroll down to the list of genres.
Some more info about genres and how they are / aren't handled by Mp3tag: /t/18135/1
