I'm using Mp3tag in conjunction with dBpoweramp to clean up my library.
I thought I'd easily be able to move everything to a new location on my NAS using the Tag-Filename function, but quickly found out it didn't move the entire contents of the directory, Folder.jpg was left behind in the original location.
So after some searching on this forum I found out about the tag-tag function using the field _DIRECTORY.
So basically I'd like everthing to be moved to a new location with one folder for multidisc albums and with the discnumber (if present) added to the filename.
Something seems to be wrong though because I tested this with one album (not multidisc and no discnumber tag) and ended up with this folder path:
I:\MusicNEW\Bobby Bland & B.B. King\I Like to Live the Love\07 - Goin' Down Slow</b>01 - Three O'Clock Blues.flac
07 - Goin' Down Slow is the first track in the list in mp3tag, coincidence? I think not?
If you want to move a whole DIRECTORY then you should leave out anything that has to do with the filename.
So
I:\MusicNEW\%albumartist%\%album%[$num(%discnumber%,1)-]$num(%track%,2) - %title%should only be:
I:\MusicNEW\%albumartist%\%album%\
If you want to also rename the file then do that before you move the whole directory (or afterwards) - but do it in 2 steps.
Currently my multidisc cd's are in their own folders with , disc 1 , disc 2 at the end.
I'm guessing that firstly moving everything to a new directory will put all the tracks from disc 1 and disc 2 in the same folder? Then it'll be easy to rename the individual files from there?
If you use an absolute path then the current set of files from the source folder are moved to the target folder.
If you rename a folder then you must have the whole folder structure ready in that respect that you cannot generate any new folders - you can only keep the current number of folders or merge several folders to a lower number.
That is why I cannot answer your question as I do not know if you already have separate folders for multi-disc albums or whether this should be the result after moving the files.
Although you say that the files are in separate folders, the format string that you supplied
uses the optional discnumber part as part of the filename and not as a folder name.
This one would:
I:\MusicNEW\%albumartist%\%album%[$num(%discnumber%,1)]$num(%track%,2) - %title%
As only one file (I think it is the first one) of a folder is evaluated, it is mandatory that this file has the discnumber set if that is to be used.
I assume that "Live" is the name of the album.
So an action of the type "Format value" (or the Convert>Tag-Tag function) for _DIRECTORY and the
Format string: i:\musicnew\%artist%\%album%
should move all the files from the 2 folders to a single (new) one.
If you already have files with the name "folder.jpg" in the 2 folders, you will be asked if the second file should overwrite the first one.
