I'm a mac user. I want to edit the file names so that there are capital letters for artist, album, etc. But the Action button I used on a PC before, CD-R, does not work when I use it on my mac. How do I fix this?
Could you be a little more specific?
Why do you use an action to get tracks for a CD instead of an action to convert the case if you want to capitalize letters?
To create filenames from tags can be achieved (best/easiest) with the function
Convert>Tag-Filename.
If I use the Convert -> Tag Filename option that does create the file pattern I prefer. But it will not change the the artist, album, or titles to words with capital letters. When I choose the Action option, at least on a PC, it capitalizes the first letter of each word, so that the artist name is capitalized, the album name is capitalized and so on. On my Mac, this does not work. I have to manually go through each file and capitalize each letter, which is tedious and not practical when you have over 100 GB of music files you want properly tagged.
