Only filename appears on my portable mp3 player
My Mp3 player only shows the filename as the song that is currently playing. Why doesn't it show me the artist and song title? Is the tag defective?
Thanks for your help!
Trav
This is probably a question that only the player's support can answer in depth.
You could check: what kind of files are these? MP3, MP4, FLAC, WAV?
If they are MP3 files: which tag versions do they have? V1? V2.x? APE?
Are the files OK?
Here is a list of programs to check the consistency:
