%_path% not work in TCMD
[#1]
MTTOOLSNAME=TotalCmd
MTTOOLSPARAM=/o /p=r /r="%_path%"
MTTOOLSPATH=..\..\..\..\Sistema\TotalCmd\TOTALCMD64.EXE
MTTOOLSINST=0
Why %_path% not work in this tool?
Maybe (untested!) you need to write
MTTOOLSPARAM=/o /p=r /r="%%_path%%"
or
MTTOOLSPARAM=/o /p=r /r=%_path%
also this suggest not work.
Please show us a screenshot from your above settings window.
MTTOOLSPARAM=/o /p\u003dr /r\u003d"%_path%"
this work, problem has =.
ty.
Again: Please show us a screenshot.
The problem occurs if you manipulate the tools.ini file directly.
(You should not change it directly!)
If you enter the parameters in Mp3tag for Tools like this:
Mp3tag translate it automatically and reusable to
Just for completeness:
The used command line parameters for Total Commander are
/O If Total Commander is already running, activate it and pass the path(s) in the command line to that instance (overrides the settings in the configuration dialog to have multiple windows)
/P= Sets the active panel at program start: /P=L left, /P=R right. Unfortunately this does not work (v6.53) with the Parameter /O currently.
-> The command line wiki page seems to be pretty outdated, TC is currently available as v11.03 stable and v11.50rc3 beta
/R= Set path right window
