Hi there,
Can someone help me to create a script to change this:
do?.i cho`em de^'n to doi cho em den Thanks so much
Hi there,
For this special case you can use Mp3tag's replace function:
$replace(%title%,?,,`, ,.,,^,,'',)
(supposed that the string is held by the tag field TITLE).
DD.20081121.1834, DD.20150204.1840.CET
Yes, that was a song title. Thanks so much.
I just got a chance to try out the script, but I could not get it to work, since I am so new to this.
I created a New Action ==> Replace ==> Name: (Accent) ==> field: All ==> Original: "All" ==> Replace with: $replace(%title%,?,,`, ,.,,^,,'',,)
But it did not work.
I also want to replace this: 01 Về Đây Nghe Em ==> Ve Day Nghe em
Thanks
K
Do learn about the difference of 'actions' and 'scripting functions', see Mp3tag help file.
Use action 'format value' with scripting function '$replace()' in the edit box 'Field'.
Read topic /t/7279/1
and try it out.
DD.20081130.1107.CET
