Dear all
I was just wondering if there is any possibility on connection with MP3TAG to generate a music catalog and print it.
I was using musicnizer.com which was doing the job quite well. As they stopped supporting the software (which has some serious bugs) and do not answer the requests I am looking for another solution.
Thanks.
Check out the export function in the WIndows version of MP3tag.
But I think that you should already know that:
Yes I know. But did not find something to print like this sample: Dropbox - Alben.de.pdf - Simplify your life.
Any suggestion?
Do not expect anything ready-made.
But the export function should enable you to create an export script that you then import into a formatter to create the final output.
Here is an example for the proceedings:
