Hi everyone,
I use the 326d 64bit version of MP3Tag and already in previous versions I have experienced some problem with files in .mp3 format, that is, only the file name of these files is imported in MP3Tag while the other fields (for example Title, Artist, etc.) remain blank.
If I use the CONVERT\Filename-Tag command to automatically fill in the Title and the Artist fields, the change is not accepted.
The same thing happens if I try to manually fill in the blank fields; after saving, MP3Tag does not accept the changes.
Below you can find the link to a file among those that gave me this type of problem.
I don't appear to have changed any MP3Tag settings, so any suggestions would be greatly appreciated.
(too fast to type)
and then I restarted MP3Tag.
My rough solution helped, but I'm a little bit confused now, because if I undo the changes, everything is anyway fine.
