In relation to this problem, I myself struggle with compiling albums from different artists. It would be really great if the autonumbering also included the option of a "random" autonumbering. Because now MP3Tag neatly sorts the titles alphabetically and I have to manually give them a unique number.
What would the random sequencing accomplish? You can sort the selected fields by any of the fields alphabetically, or numerically. But if you prefer, you can manually drag files up or down the list, or. Even “randomize” it by using the top-left column. Once you have the files in the preferred order, you can then run the wizard and the numbering will maintain that order.
I would like to add that you find the function to randomize the sorting order described in the documentation:
