Reading GEOB?
Is there any way to display specific GEOB fields in "Columns view"?
GEOB size=361 MIME="application/octet-stream" File="" Descr="Serato Markers_" Binary data size=318 Content: ".......................0........P............2.......`...............L.....:N............3..............................................................
...." (02 05 00 00 00 0e 00 00 00 12 10 7f 7f 7f 7f 7f 00 7f 7f 7f 7f 7f 06 30 00 00 01 00 00 00 01 05 50 7f 7f 7f 7f 7f 00 7f 7f 7f 7f 7f 06 32 10 00 01 00 00 00 03 60 0f 7f 7f 7f 7f 7f 00 7f 7f 7f 7f 7f 00 00 01 4c 01 00 00 00 06 3a 4e 7f 7f 7f 7f 7f 00 7f 7f 7f 7f 7f 06 33 18 00 01 00 00 00 07 2e 0e 7f 7f 7f 7f 7f 00 7f 7f 7f 7f 7f 00 03 18 00 01 00 7f 7f 7f 7f 7f 7f 7f 7f 7f 7f 00 7f 7f 7f 7f 7f 00 00 00 00 03 00 7f 7f 7f 7f 7f 7f 7f 7f 7f 7f 00 7f 7f 7f 7f 7f 00 00 00 00 03 00 7f 7f 7f 7f 7f 7f 7f 7f 7f 7f 00 7f 7f 7f 7f 7f 00 00 00 00 03 00 7f 7f 7f 7f 7f 7f 7f 7f 7f 7f 00 7f 7f 7f 7f 7f 00 00 00 00 03 00 7f 7f 7f 7f 7f 7f 7f 7f 7f 7f 00 7f 7f 7f 7f 7f 00 00 00 00 03 00 7f 7f 7f 7f 7f 7f 7f 7f 7f 7f 00 7f 7f 7f 7f 7f 00 00 00 00 03 00 7f 7f 7f 7f 7f 7f 7f 7f 7f 7f 00 7f 7f 7f 7f 7f 00 00 00 00 03 00 7f 7f 7f 7f 7f 7f 7f 7f 7f 7f 00 7f 7f 7f 7f 7f 00 00 00 00 03 00 7f 7f 7f 7f 7f 7f 7f 7f 7f 7f 00 7f 7f 7f 7f 7f 00 00 00 00 03 00 00 00 00 00), GEOB size=357 MIME="application/octet-stream" File="" Descr="Serato Markers2" Binary data size=314 Content: "..AQFDVUUAAAAAFQAAAAAJEADMAAAAAEVuZXJneSAzAENVRQAAAAAVAAEAAELQAMyIAAAARW5lcm
d5IDUAQ1VFAAAAABUAAgAA8A8AAADMAABFbmVyZ3kgNwBDVUUAAAAAFQADAAGdTgDMzAAAAEVuZXJneS
A
0AENVRQAAAAAVAAQAAdcOAADMAAAARW5lcmd5IDcAQ1VFAAAAABUABQACEM4AzADMAABFbmVyZ3kgNQB
D
VUUAAAAAFQAGAAJKjQAAzMwAAEVuZXJneSA3AENVRQAAAAAVAAcAAvfMAIgAzAAARW5lcmd5IDcA" (01 01 41 51 46 44 56 55 55 41 41 41 41 41 46 51 41 41 41 41 41 4a 45 41 44 4d 41 41 41 41 41 45 56 75 5a 58 4a 6e 65 53 41 7a 41 45 4e 56 52 51 41 41 41 41 41 56 41 41 45 41 41 45 4c 51 41 4d 79 49 41 41 41 41 52 57 35 6c 63 6d 64 35 49 44 55 41 51 31 56 46 41 41 41 41 41 42 55 41 41 67 41 41 38 41 38 41 41 41 44 4d 41 41 42 46 62 6d 56 79 5a 33 6b 67 4e 77 42 44 56 55 55 41 41 41 41 41 46 51 41 44 41 41 47 64 54 67 44 4d 7a 41 41 41 41 45 56 75 5a 58 4a 6e 65 53 41 30 41 45 4e 56 52 51 41 41 41 41 41 56 41 41 51 41 41 64 63 4f 41 41 44 4d 41 41 41 41 52 57 35 6c 63 6d 64 35 49 44 63 41 51 31 56 46 41 41 41 41 41 42 55 41 42 51 41 43 45 4d 34 41 7a 41 44 4d 41 41 42 46 62 6d 56 79 5a 33 6b 67 4e 51 42 44 56 55 55 41 41 41 41 41 46 51 41 47 41 41 4a 4b 6a 51 41 41 7a 4d 77 41 41 45 56 75 5a 58 4a 6e 65 53 41 33 41 45 4e 56 52 51 41 41 41 41 41 56 41 41 63 41 41 76 66 4d 41 49 67 41 7a 41 41 41 52 57 35 6c 63 6d 64 35 49 44 63 41)
Specifically fields with description: Descr="Serato Markers_ and Descr="Serato Markers2"
Both include binary data (base64 encoded)...no wish to actually decode it, but just show it.
Also, somehow export it if needed?
If it is not possible to show it, how to indicate if it is present in file, or not?
Would it be even possible with MP3Tag?
This question is directed to the Mp3tag developer himself.
You may find and read some informations about the ID3 frame GEOB ...
http://id3.org/id3v2.3.0
... search for "4.16. General encapsulated object".
You may find and read some informations about the ID3 frame GEOB within the Mp3tag forum ...
https://www.google.de/search?q=site%3Aforums.mp3tag.de+GEOB
As I understand ... the ID3 frame GEOB is not supported by Mp3tag.
You may try out "FFmpeg" ...
https://www.ffmpeg.org/
http://ffmpeg.zeranoe.com/builds/
http://jonhall.info/how_to/setup_and_use_ffmpeg_on_windows
http://jonhall.info/how_to/dump_and_load_m...ata_with_ffmpeg
DD.20150720.1324.CEST
Then it does not modify it either?
Even if _TAG or _ALL (bad practice, not reccomended, I know) is used in Actions processing? :rolleyes:
As I understand ... the pseudo tagfields _TAG and _ALL ...
are defined by the Mp3tag developer himself for the usage within Mp3tag, ...
and you can expect and rely on, ...
that these special placeholders support only those tag fields, ...
which Mp3tag is able to handle.
DD.20150720.1336.CEST
This can be actually tested, you can dump that info with mp3diag,
do some pseudo field action (or even remove all tags) and after that dump contents with mp3diag again and compare results.
Will try that later...just for interest and report here, what would actually happen, as a backlog.
OK, removing Tag`s will definately delete those GEOB fields as well (it removes absolutely everything).
Case conversion (using pseoudo tag _TAG) for example, seems to have no effect at all on those. (which is actually good and desirable behaviour).
So IMHO we can conclude, that pseudotag _TAG at least does not include any GEOB fields.
Exiftool can read and extract binary tags from mp3 files and has some process control built in e.g.
You may be able to make it do what you want.
http://www.sno.phy.queensu.ca/~phil/exifto...cessing_control
This will output the GEOB frame to a similarly named text file for each mp3 file in MyDir matching the condition
exiftool -ID3_GEOB -if "$ID3_GEOB =~ /Serato Markers/" -b -U -ext mp3 -w .txt -r MyDir .
Many more things are possible with Exiftool. :slight_smile:
But editing tags for audio files is not one of them.
Still, maybe Florian could make it possible to display somehow in columns view that file has GEOB data?
For example "GEOB" True/False style... :rolleyes:
Does removing id3v1 only removes GEOB too?
I discovered interesting issue, I have some files which cannot be played back with Sennheiser Captune: https://play.google.com/store/apps/details?id=com.sennheiser.captune
They play back fine on every other player/device.
Removing id3v1 with mp3tag somehow fixes the issue, still investigating the reason.
Only Captune and this batch of files seem to have the issue, when files are checked with MP3Diag, it says: "invalid characters in id3v1 tag".
Maybe @Florian can comment on this?
Not sure what the question is, but removing ID3v1 doesn't remove ID3v2 GEOB frames. This only happens if you remove ID3v2.
Thx @Florian, that actually was the question.
How to get rid GEOB, if needed, using Mp3Tag.
You could cut the whole tag from the file using Ctrl + X and paste it back using Ctrl + V.
Background: Mp3tag omits unsupported fields when writing fresh tags — if you simply update an existing tag, also unsupported fields are preserved.
@Florian
It would be useful to have this Ctrl+X + Ctrl+V combination available as an action, so it can be performed on many files, one file at a time.
For a large file set that would be much safer than cutting all tags at once and pasting them all back separately i.e. if anything goes wrong during the paste you will lose information!
Please accept this as a feature request.
:white_small_square: :white_small_square: :white_small_square:
This is also very important, when we want to change the tag type or encoding, using this method. So +1 vote.
