I would like to suggest that, in a future update, we be given the ability to turn off the audio part of the Messages.
I listen to songs while I am using Mp3tag, like the Messages, but don't need to hear the constant audio interruptions from the Confirmation Messages.
Thank you.
As MP3tag uses the Windows built-in message dialogues, it is up to you to modify the setting for messages in the window control panel.
See also here:
