Removing Parenthesis in Titles Along with Spaces
I found this Action:
It works but it leaves a space in the title. It's not that big a deal when the parenthesis are at the end, but it's an issue when they're at the beginning. "(I Just) Died in Your Arms" becomes " Died in Your Arms".
Can the parenthesis be removed along with the extra space?
Edit: Here's what that linked Action is doing so you don't have to download it to see:
Regular expression:
You would have to show us what you typed in as code.
it could be that your code is missing a space character at a vital position.
Or you could use another action of the type "Format value" for TITLE
Format string: $trim(%title%)
Edit:
Try
\s*\(.+\)\s*
Works perfectly. Thank you!
