My Artist Sort got all messed up using Picard (never doing that again even if it reduced album art metadata). Wanted to sanity check and ask here after searching the forum but couldn't find my exact issue.
Current Song metadata:
Title: Don't Touch Me
Artist: Bettye Swann
Sort Artist: Swann, Bettye
Desired Song Metadata:
Title: Dont' Touch Me
Sort Artist: Bettye Swann
I figure I can use an action to replace Sort Artist with Artist name but couldn't get the regex right. Currently this issue is moving Bob Marley to the M's section in macOS Music and the song above to the S section etc. This is an example but I don't mind adding it where there isn't anything Replace ARTISTSORT with ARTIST. I want to replan all ARTISTSORT and mirror ARTIST in that field.
This is the expected "correct" tag field value for Artistsort for traditional music cataloging. For band names only leading terms like A, An, or The are dropped in most cases. For Artists using their proper names, sorting is by last name, first name.
If your personal preference is to use first name last name in your own library, perhaps there is a setting in Picard to change that before you run any further data through it? Otherwise as suggested by @ohrenkino you can use the Format Value in the converter to apply the value from Artist to Artistsort.
