Add a 5-star rating column option
Hello @jcguy, welcome to the Mp3tag community.
I don't quite understand your request; could you elaborate on your idea?
Hello @jcguy,
Are you referring to the 5-star rating option in the column, similar to the iTunes rating system?
Hello @jcguy,
I did some research. @ohrenkino already answered this question and explained how to proceed in January 2010; here is the link:
Yes, add a 5-star rating to the column list options
And? Did the suggestions in the linked thread work out for you?
You could also follow this suggestion to enter stars in a column as rating values:
Thanks for your examples @ohrenkino and @LyricsLover... ![]()
I did a test with iTunes, as ohrenkino mentioned, iTunes stores them locally in a database on the PC, and the data doesn't appear in Mp3tag.
My question is, can we use a command in the Mp3tag program to retrieve the iTunes data from the PC's database and transfer it to Mp3tag?
No.
But you could create 5 automatic playlists in iTunes, one for each rating star and then drag&drop the contents from each playlist into MP3tag and set the rating value in MP3tag.
Thanks @ohrenkino,
I think I understand your method, which is very simple.
Example: In iTunes, I take 3 audio files and check that they are rated 5 stars.
In Mp3tag, I take the same 3 audio files at the same time, click in the rating field, choose 5 stars, and save all 3 files once. We then have the same ratings in iTunes and Mp3tag…
