I propose a simple change of blocking of the CTRL + Z keyboard shortcut, when user is focused in the Filter Box
The purpose o this is also simple: when I write some filtering expression, I often accidentally delete some portion of it and then without thinking press quickly the CTRL + Z; which in turn instead if bringing me the deleted potion of expression, reverses my last change done on files. And sometimes I do not even remember what was the change. And I just can't help this impulse no matter how many times I perform this error
That current behavior of Mp3tag is just so annoying and counterproductive
3] Change any tag field in that file by writing >>TEST-1<< in it -> I changed the band name
4] Click in filter box -> ok
5] Write >>TEST-2 TEST-3<< in filter box -> ok
6] Select >>TEST-3<< -> ok
7] Delete it -> it is gone
8] Press CTRL + Z, as if you were trying to bring back deleted >>TEST-3<< in some word editor or Notepad
And now: what happened? -> I see only test-2. The files list gets updated so that the file with "test-1" disappears (which could be expected as I do not have a file with "test-2" as data)
When I remove the filter, the file with "test-1" is shown again.
In short: Ctrl-Z has no special function in the filter box.
I press CTRL + Z while focused in filter box, and the last work done on some tag field[s] or filename is reverted. It's right there in the Edit drop down menu, at the very top of it:
Undo Tag - Filename Ctrl + Z
This shortcut works for me anywhere, as long as the Mp3tag window is at the front [and I wish it would not when I am in the filter box]
I can confirm that pressing [Ctrl-Z] within the Filter edit line has a bad effect on the tag data:
it removes the previously inserted tag-field TEST-1.
This works like "Hotkey: Ctrl + Z", "Undo the last operation" from the menu "Edit".
It is probably better to disable this keyboard shortcut while working in Filter Edit mode.
