Restricting maximum rating value
I am using some code that I found on here that allows ratings numbers to be displayed as stars in the Ratings column.
$if(%rating winamp%,$repeat($char(10032),%rating winamp%),$if(%rating wmp%,$repeat($char(9733),%rating wmp%),$if(%rating mm%,$repeat($char(10026),%rating mm%),$repeat($char(10061),$if2($ifgreater($regexp(%popularimeter%,'^.+\|(\d{1,3})\|\d+',$1),196,5,$ifgreater($regexp(%popularimeter%,'^.+\|(\d{1,3})\|\d+',$1),128,4,$ifgreater($regexp(%popularimeter%,'^.+\|(\d{1,3})\|\d+',$1),64,3,$ifgreater($regexp(%popularimeter%,'^.+\|(\d{1,2})\|\d+',$1),1,2,$ifgreater($regexp(%popularimeter%,'^.+\|(\d)\|\d+',$1),0,1,))))),0)))))
It works very well, but I would like to limit the maximum number of stars to 5, and display a message in the column if a number greater than 5 is entered into the ratings field (to warn that it is an invalid value).
I wouldn't know how to add any extra code to the complicated code above without breaking it, so I would appreciate some help. Thanks.
Maybe @Doug_Mackie (the original autor of this code) can explain how you could achieve your alternate message.
At least for values in %popularimeter% every number greater then 196 will result in 5 stars. I don't see how you can get anything bigger then 5 stars with the above code.
Maybe the code has to be limited to 255 as max value with something like in this example:
I'm not talking about altering the rating code to scale differently to give different results. I just mean a simple function that says if value in this column is above 5, show <error> (or whatever) instead of showing like 8 or 9 stars or whatever the value is.
This is a very simple and basic command that I could probably manage to figure out if I was dealing with a simple formula rather than the complex one shown above.
Sorry Lem, but I wrote that script nine years ago and I don't remember much about it except that it was hell to figure out! I myself stopped using ratings long ago because I found that my judgment was not very reliable. Often I would find that my initial rating was not even close to my rating on re-listening to the track a few years later.
I don't recall that my script would allow more than five stars in the Mp3Tag version in use at that time. A while back I think that Florian announced some changes to how ratings work internally but I have been unable to find that reference. [Anyone else know where to look?]
As for validating the rating inputs, as far as I know Mp3Tag scripting does not include the ability to show conditional messages.
Which version of the rating do you actually use?
The code is so longish as it has to cater for the 3 rating incarnations in the shape of
%popularimeter%
%rating mm%
%rating wmp%
So one could shorten the expression considerably, if it did not have to take care of all variations.
In a quick&dirty version this might show some effekt:
$ifgreater($len($if(%rating winamp%,$repeat($char(10032),%rating winamp%),$if(%rating wmp%,$repeat($char(9733),%rating wmp%),$if(%rating mm%,$repeat($char(10026),%rating mm%),$repeat($char(10061),$if2($ifgreater($regexp(%popularimeter%,'^.+\|(\d{1,3})\|\d+',$1),196,5,$ifgreater($regexp(%popularimeter%,'^.+\|(\d{1,3})\|\d+',$1),128,4,$ifgreater($regexp(%popularimeter%,'^.+\|(\d{1,3})\|\d+',$1),64,3,$ifgreater($regexp(%popularimeter%,'^.+\|(\d{1,2})\|\d+',$1),1,2,$ifgreater($regexp(%popularimeter%,'^.+\|(\d)\|\d+',$1),0,1,))))),0)))))),4,Warning,%popularimeter%)
In general: the expression transforms the display but relies on an existing value. So it cannot be used to warn while data is being input.
So I would assume that it would be much easier to use a filter and list the invalid values, esp. as the formats vary depending on the target. E.g. a value greater than 5 is perfectly ok for the native format of POPULARIMETER. If this is supposed to get serious, it would be necessary to implement some kind of syntax check.
What about 3 additional columns with the content of
%popularimeter%
%rating mm%
%rating wmp%
and then simply sort this columns (by a click on the column header).
You will see the values bigger then 255 or whatever value represents more then 5 stars in your environment.
