Sharing custom actions on macOS
Hi
Where are the custom actions located on Mac, cannot locate he folder
Thanks
Hi and welcome!
There is no dedicated folder, Mp3tag uses macOS defaults system for storing the actions. More on that already discussed here:
Thanks you for your prompt response. Would be great to see an easier way of sharing Custom Actions in future updates. Thanks again and keep up the great work
Thanks for your feedback! For my understanding: is it about sharing of actions with other users or do you have a different use case in mind?
That's precisely the reason would be nice to share scripts for example I created Cyrillic to Latin converter , it's not somewhat time consuming so would be easier for people to download the scripts rather than having to create from scratch
I've just released Mp3tag for Mac v1.10, which adds support for exporting and importing action groups as JSON files.
