Good evening,
Please, I connected today my NW-A105 to my laptop by mp3tag last version did not recognize it. My NW-A55 works perfectly with mp3 tag.
A105 works under Android 9...please any help, support and guideline will really appreciated.
Regards,
Wilfredo
Does this show a drive letter in the Explorer window? When you connect it by USB, you may have to drag from the top and set the USB setting to file transfer mode on the A105.
Hi MotleyG,
I realized that, no drive letter is shown even in transfer mode.
Hello everybody, and thanks to the programmer for this awesome software.
I have my personal music library copied on the microSD of my smartphone, and would like to load it on Mp3Tag to execute a mega-ID organization.
Anyway, if i try to select the directory with the SD card inserted in the phone, MP3TAG says me that the folder is not valid.
Please, does someone know how to solve this?
Thanks a lot!
or here:
Hello,
I cannot add a folder from my Android device (it uses MTP connection - media transfer protocol), when I select the storage I cannot see the folders on the right side. If I expand the folder in tree and then select a folder, I got an error message 'The folder name is invalid'.
Any help on this?
Thanks.
[image]
It's a device problem, no MP3tag problem.
The device has to appear as drive in the OS, otherwise the data cannot be accessed.
