Hi Florian,
not sure if this is placed in the correct forum.
Since updating I've noticed that the "Metadata Album" section isn't sorted alphabetically anymore for special characters like before. I don't know if that's intended behaviour, but I while using Beatport web script I used to see _TIME_CHECK first in the "Metadata Album" for single track releases.
After updating it's sorted to last and I have to scroll down to see it.
A quick fix would be to rename _TIME_CHECK object to AAAAA_TIME_CHECK or something, but it could be a small sorting bug as well. Don't know how you want to treat it
