coyote
September 11, 2023, 11:59pm
1
I want switch from the 32-bit version to the 64-bit version but I don't want to lose my Actions. I see that the Uninstaller only optionally will "Remove configuration data at C:\Users\zzz\AppData\Roaming\Mp3tag"
Are the Actions in that configuration data?
Florian
September 12, 2023, 2:02am
2
Yes, and you can always create a backup to be sure:
Can I keep my settings when updating to a new version?
Yes, you can install a new version over an already installed version. The installation program will keep/upgrade your settings.
Can I backup my settings or use them on a different computer?
Yes,
To backup your settings, please choose File → Save configuration.
To restore the backup, you have to unzip the backup archive to the folder that opens when you choose File → Open configuration folder. Close Mp3tag to ensure that all files c…
Please don't forget to follow the additional notes here:
I've released a 64-bit version of Mp3tag a few days ago and received a few questions about differences between the 32-bit version and the 64-bit version.
To make it short, there should not be any noticeable differences except for two things:
The 64-bit version uses 64-bits to address memory and is no longer limited to 2 GB per application. While the Library feature of Mp3tag is already a very viable solution for large libraries, loosening the memory restriction is one of the key benefits of …
