How to switch First and Last name I know, but how to switch multiple names I don't.
ie Bing Crosby & Grace Kelly - True Love to change to Crosby, Bing & Kelly, Grace - True Love.
I've tried numerous expressions but can't solve this one.
I think you'll find that you have few enough multiple-artist tracks that doing it manually is sufficient. There's no real need to automate it for the relatively small number of instances that you'll encounter in your library.
If that's a file name or track title (from a compilation, for instance) then I wouldn't change it, as I find the original to be more readable. However, I would use it for a sort field:
You can do it of course, but it's a lot of work.
The basic solution is to put the tags in the filename, and then F around with the filenames, and then put it back.
Kind of like solving the first layer of a Rubiks Cube <<< yes, geekgrrrl frame of reference here
Step 1
Renaming the files with the tags. This should be easy enough. The result is that you have many file named Bing Crosby & Grace Kelly - True Love.mp3 Bing Crosby & Grace Kelly - True Love.mp3 Bing Crosby & Grace Kelly - True Love.mp3 Bing Crosby & Grace Kelly - True Love.mp3
of course, they would all have DIFFERENT NAMES! I just copy pasted, cos i'm lazy etc.
Step 2 Switching the first and last name of the files themselves.
You can do this in two ways:
A. Via Excel and a batch file (skip to below)
or
B. Via a good Filemanager, other than Windows Explorer. Like Total Commander, get it at www.ghisler.com, it's still free nagware, i guess.
It's easier if you have Total Commander, or any other application that can to Regular eXpressions
You can do that with multiple fields I guess, in your case 5 minimum.
Search for: (.) - (.) - (.) - (.) - (.*).mp3
Replace by: $4 - $5 - $2 - $3 - $1.mp3
You should test on a small number of files, say 5, and have back ups!
EXCEL and batch files
This is maybe easier for you,
you should get all the filenames and paste them in a textfile.
Total Commander has a button for that, but if you don't have that, type this into the Run box cmd /k dir/s *.mp3 > C:\Documents and Settings\AllMyMP3-Files.txt
The textfile will look like this:
Then, you should put comma's after each first name, and after each last name.
in short, edit the textfile until it looks like this:
Note that you should add as a FIRST LINE
FirstName1, Lastname1, FirstName2, Lastname2, Title
Save the file with the extension .XLS or .CSV
Open it with Excel
if it worked, you should see a spreadsheet with 5 columns with the headers:
Swap the columns around until it they are in this order.
Lastname1, FirstName1, Lastname2, FirstName2, Title
Save the file. Save it again with a .BAT extension. That first save is just a backup.
Open the batch file in your favorite editor.
edit it until it looks like this.
Thanks!! to all of you Problem Solved. Finally I can Go on, this is great now I can use my DLNA server properly. There's still a lot of work to do but now with pleasure
