Some of my album info is not found on Discogs but when I go to their website it is clearly there. Any idea what I can do?
If you know the ReleaseID (from the Discogs website for example), you can use the Websource "Discogs Release ID".
This one should show the expected result.
Otherwise some existing example (screenshot) would be helpful.
