Tag Sources is failing timeout 12002
I am on the latest version (v3.29) but none of the Tag Sources options are working.
MusicBrainz gives the error:
Error connecting to server: musicbrainz.org
12002: 12002: The operation timed out
Discogs Artist + Album gives the error:
Failed to authenticate using OAuth (1).
The program has internet access, because "Help>Check for new version" works.
Could you please use the forum search function?
There are a number of threads that deal with this problem.
The search word "12002" should show a fair number of those.
Please try those suggestions. And if the problem prevails, please tell us, what you have tried so far.
See also here:
I increased the Timeout, and it's now working again. It must be going slow today :slight_smile:
