There are all those configurable feature and settings available at
File > Options
I my opinion it would be time saving for the user if all those entries were listed in an alphabetical order. Because that list a little too long to be forced too read most of it or to sear through it for the right thing, or having to per-memorize its position
The position determines the shortcut.
So Ctrl-1 calls the first tool , Ctrl-2 the second.
So, a new order when adding a tool would be more surprising than counterproductive, IMHO.
It is true, that I do not go around changing them left and right every other day. And that is precisely the point: when I do need to change something once a couple of weeks or even months, I am forced once again to read through the list, even if I remember what entry I am looking for
It is such little things that when multiplied through dozens of programs and ~350 days a year that make certain users annoyed with feeling of actual waste of time
This is just great- a perfect example of how even a vastly experienced user can be confused by repeated usage of name Tools in Options
I was talking about the first Tools, and not the second. So your answer here is exactly the kind of situation that can be avoided when that other proposition of mine gets through
Yes. And also CorelDRAW. But the difference between those two is Corel allowing the user to greatly adjust the menus, shortcuts, icons and other windows - thus in Corel I do not see such the chaos like in Excel
Or it could be that the original description was confusing and therefore counterproductive. That what you refer to is the dialogue "Mp3tag Options" - so the correct reference to the dialogue title would have been appropriate.
And if you refer to the options tree ...
I just had a look at foobar and there the first letters are:
CDKMPSTA
My printer driver as a tree for options and shows
EVBTI
The program I use for data transfer has an options dialogue with the subsections' first letters
VSOVSMDHEE
so apparently, there are other sorting criteria than alphabetically only.
So, with a little sympathy for the people who work on MP3tag I would grant them the good will that the order is not completely random but follows defined criteria.
And these may also be that something is easier to be maintained or developed like that over the time.
On the other hand: it is by no means mandatory for a program to function that it displays functions in a way that a user can relate to. It may be nice sometimes, but also it may be possible that there are limitations on the user side to grasp the concept.
In such cases the user simply has to learn the way it works.
