After editing & saving my files to a flash drive, My track lisitings are not in sequential order (1-17) . They are jumbled & i cant seem to correct this. Does anyone have the answer for this.
Thanks
Thanks
If you have track numbers with 3 digits and leading zeros then the Windows Explorer inteprets these as octal values instead of decimals.
Thanks for the reply, but i'm using 1-17 as track numbers. i'm not leading with zeroes or using 3 digits. how do i correct this?
Now it would be nice if you could supply a lot more details along the guide lines for support requests:
I have a 17 music files numbered 1-17 on my computer. After tagging the files using MP3tag. I copy the completed files to my flash drive, so that i can play it in my car. The files are not in the order that i have them numbered in.
Is it a player problem?
Which program shows the garbled order?
What kind of files are these?
Which tag fields have you filled? Show us the extended tags dialogue.
What does the filename look like?
I'm chiming in here, just to mention that some car stereos require the files to be named in a sequential order.
So it might be not enough to assign the track numbers, but instead also rename the files so that the filename starts with the track number padded with leading zeros.
You can use Convert → Tag - Filename for that, using the format string from the example in the documentation:
If you're experiencing issues with the order of your music files after tagging them using MP3tag and copying them to your flash drive, there are a few potential reasons for this:
Sorting method: Many media players will sort files alphabetically by default. This means that even if your files are named with numbers (e.g., 1.mp3, 2.mp3, etc.), they might not necessarily play in numerical order if the media player is sorting them alphabetically.
Metadata tags: While MP3tag allows you to edit metadata tags such as title, artist, album, etc., it's possible that the media player in your car is prioritizing these tags over the file names when sorting the tracks. If the metadata tags are not set correctly or consistently across all files, this could result in an unexpected playback order.
File system order: Depending on how your files are stored on your flash drive and how your car stereo reads them, the playback order may be influenced by the file system's organization. Some systems may sort files based on their creation or modification dates, rather than their names.
To address these issues:
Check the sorting settings on your car stereo or media player. Look for options to sort files by file name or track number rather than by title or metadata.
Ensure consistent metadata tagging across all your files. Use MP3tag to edit the metadata tags such as track number, album name, and artist name so that they are consistent and accurate across all files.
Rename your files using leading zeros to ensure numerical order (e.g., 01.mp3, 02.mp3, ..., 17.mp3). This can help ensure proper sorting, especially if your media player sorts files alphabetically.
Organize files in folders: If your car stereo supports folder navigation, you could organize your files into folders named according to the desired playback order (e.g., "01", "02", etc.).
By addressing these potential issues, you should be able to ensure that your music files play back in the desired order on your car stereo.
Thank You for your Help. I will try your suggestions & see if that works.
Thanks again
