Why do track numbers disappear whenever I select more than 1 file from the List, to make global changes and saves in Tag Panel? I just noticed this and have removed many that I need to manually re-add.
I started with auto numbering albums, and then made changes files tags.
They don't disappear when I edit fields on the List, but then I have to copy, paste and, and enter to navigate from start to end to manually enter numbers.
I'm not sure if I changed something to make this happen. I couldn't find any related topic upon search in this community and hope someone can help prevent the track numbers from disappearing whenever I edit highlighted files from the field and make globals changes in the Tag Panel after Save.
After selecting more than one file on the List to make global changes, I need to make sure the track number label is <keep>. They numbers won't disappear when I do this. Now I understand that when more than 1 file is selected, only shared text is displayed in the placeholders, not when the text differs. I never noticed this until a week after using this program. But now I do.
Thanks again for your hints that helped answer all of my questions that I researched in this community and discovered a few days ago after using an MP3Tag editor for the first time.
So the display changes to <keep> which would have been a much more exact description than to say the numbers disappear.
And as you don't know what I expect as the "exact" description and I don't know what you mean by "disappear" it is always the easiest way to avoid misunderstandings and doubts by supplying a screenshot that shows the problem.
Just a footnote: the same behaviour should be observable for TITLE as well - or the lyrics.
Why the covers disappear
cannot be answered by selecting multiple tracks unless the all have different embedded pictures - but then it should be noted next to the picture frame that this is the case.
