I installed a new hard drive. I forgot that I had a ton of format strings in MP3TAG before. I wish I had copied them all into a text file but I forgot.
I do however have access to the old hard drive. It is connected as a USB external drive. I have access to the Programs folder. My question is - Is there a file on the old hard drive that I can copy into the programs folder on the new hard drive or any other way to get these format strings from the old drive?
Thanks in advance - I didn't realize how much I used those strings until I ripped my first CD on the new system.
See the FAQs for possible places where your settings might be:
In your new installation the data should be stored in the folder %appdata%\MP3tag unless it is a portable installation.
