With no changes made, i am having issues with lyrics (they have worked fine in the past). Using musixmatch, i now get lyrics that are incomplete. As in,
eng||Just want to live naturally
Time told you, and you told meCan′t ....
The html part displays when viewing the lyrics and they are truncated. Anyone have any idea what i am doing wrong?
In mp3tag, in my tag panel i have "UnsyncedLyrics". I copied and pasted the post from there (it's where the software places the lyrics). I hope that helps, is that what you mean?
So it is a dispaly problem in the tag panel?
Did you have a look at the extended tags dialogue to check if the data unsyncedlyrics is complete?
In the tag panel, the display field should be a multi-line field.
It is in the display panel and everywhere else it displays (as in my player).
Yes, it is the same, truncated and with html code visible.
The display field is one line.
Could you please tell us a step by step what you do?
1.) you select a song in Mp3tag and then press what? Or what is your next step?
2.) what do you see exactly in Mp3tag or any other used source (can you show us a printscreen)?
This is something that you could change to multiline, I would say.
The player is no good test environment as I assume that the first step goes with MP3tag.
So: what does the "Edit" Mode of that field show in the extended tags dialogue?
And: I just tested the linked web source for the track "Magic" by Nick Drake and it produces just the lyrics with all the line breaks and no truncation.
So tell us what you do as @LyricsLover requested.
Here are a couple screen shots. The red arrows indicate my workflow. All i'm doing is clicking on the "world" icon them choosing ok. By the way, i'm not necessarily wanting to use musicmatch, i'm just wanting lyrics to be tagged correctly, any service that works is ok by me.
to me it looks as though the field UNSYNCEDLYRICS is not truncated - a way out would be to configure the tag field for UNSYNCEDLYRICS to be a multi-line field (as I said before).
If you select the field UNSYNCEDLYRICS and press the edit button you will see that all the text is there.
Why that piece of HTML code appears - I don't know, could be the source.
Another note: Just pressing the "Globe" Icon simply calls the last web source script that you used.
It would lead to more control if you used the menu Web Sources and selected that script that you really intend to use.
Thanks Ohrenkino,
'Musixmatch' is the only script i have installed. it's the only one i can get to 'work', even though it doesn't work very good at all. Not sure having a choice of scripts is of help to me as I've in the past tried many of the scripts found at [WS] Import lyrics from websites, but have had no luck. Maybe i am doing something wrong? I searched for a step by step tutorial as to how to install and or use them correctly but was unable to find one.
The main difference could be that I use this&Lyrics#Musixmatch02.rar web source script, from the first post in [WS] Import lyrics from websites . The last change to this musixmatch websource script was made 2021-02-07.
Please try it with the same websource script. @ohrenkino already told you, how you find the necessary informations about the installation. If you do the same again as you did here, you should get it working.
Sorry for being so ignorant about this subject. Back in January i was able to get it working, however i now see that it was not working correctly, i went back and see the html tag is in all my lyrics since then.
At Menu Tag Sources – Mp3tag Documentation i am only seeing a description of what they are not how to install correctly (location & how). Am i missing something?
