Hi, so as the topic says, using "Refresh file view" after using a _DIRECTORY "Format value" (so basically rename the DIR using a quick action) returns blank filelist (no files appear in the list view), the "Directory:" field in the left Tag panel has the correct and valid renamed DIR path and a simple Enter key pressed in the field refreshes the filelist and the files are displayed again and after that if I use "Refresh file view" button again it refreshes the filelist and the files are visible as normal.
I am using the latest 3.37.1-beta.1 version and this is happening from previous versions also.
Hopefully this is identified as a bug and can get a fix.
