V2.95 - Tag -> Filename mistreats "" in tags
When using the Tag - Filename feature, it does not handle backslashes correctly. In the following examples $ifgreater($num(%discnumber%,1), $num(0, 1), $num(%discnumber%, 1) - ,)$num(%track%,2). %title% will be used as the Format String, and the following filetree will be assumed:
Artist
├── Album 1
│ ├── 01. Erster Song.flac
│ └── 12. Letzter Song.flac
└── Album 2
├── 01. First Song.flac
├── 05. Bugged Song.flac
└── 14. Last Song.flac
The bugged song will have foo\bar as its title.
The current directory will be Artist
Expected behavior
Mp3tag ignores the backslash and renames the files the following way: (it handles the backslash the same way it handles a normal slash)
Artist
├── Album 1
└── Album 2
├── 05. foobar.flac
Actual behavior
Mp3tag does not ignore the backslash, and instead makes some rather weird naming:
Artist
├── 05. foo
│ ├── bar.flac
├── Album 1
└── Album 2
How to reproduce
- Take an example song and change its title (or some other property you later specify as content of the Format String) to include a backslash (
\) - Click on the
Tag - Filenameicon while the example song is selected, and click on OK. (Make sure your Format String uses the Tag you edited in point 1) Wait a second and look at the output.
Small notice: in the preview the filename gets displayed correctly.
