I would like to create an action that fills certain info into the comment field. The info I want to format is in 2 lines. Keying this in manually is simple, but I'd like to create an action to perform it automatically as I have to change these comments to a specific verbiage 99% of the time. I do not know how to add an enter command into a string (trying to create the action... Format Value/Comment/Line One ENTER Line Two). Any recommendations?
Thanks for the reply, LyricsLover. Yeah, this thread seems to only reference the comment field itself which I have altered properly to allow for multiple lines several years ago. Now, I'm simply looking for a way to program these specific comments automatically with an 'action'. Thanks though.
