Where's "Tag - Tag" conversion?
Just discovered this great proggie. However, how come there is no tag-to-tag conversion available? I have several songs with title tag "%track% - %title%" and of course I want to convert them to just "%title%". Of course I could first use tag-filename and then filename-tag, but I don't want to change the filenames (and tag-tag would be so much easier).
The Actions [ALT+5] are used for this.
It's [Alt+5] or Converter, Actions :wink:
Best regards,
~ Florian
Care to give an example on how to accomplish the task mentioned? Without regexp might I add, which would be total overkill for a task this simple.
How would you expect a tagger to do something "this simple" without regular expressions?
Edit: if you want to use Mp3tag and regexp, use TITLE as field, (\d*) - (.*) as regular expression and replace matches with $2
The same way it's done with Filename-Tag conversion.
Let's say we have a song with the title "01 - Song", and we want to change it to "Song".
We select Convert -> Tag-Tag
Program asks for field and we select: TITLE
Program asks for formatstring and we enter: %1 - %2
(Program shows preview - 1: 01 and 2: Song)
Program asks for new entry and we enter: %2
Press OK.
About 42 times simpler than using your suggested method.
I agree with Sentenced.......
quite a few compilation albums "Best xxxx Album in the World Ever...." type thing have the track name as "Name of Artist - Track Name" format......at the moment I use
Tag - Filename then
Filename - Tag typing %artist% - %title%
and it works brilliantly.
I too expected to see a Tag - Tag conversion entry.
Excellent piece of software btw :slight_smile:
Sentenced, AndyD,
I've added some kind of Tag - Tag converter with the new action type Guess values with the latest Development Build.
Just create a new action Guess values and use %title% as source format and %artist% - %title% as guessing pattern.
Best regards,
~ Florian
