Which Rekordbox fields are saved in mp3 tracks?
In addition to this existing topic
I have found these current informations:
Rekordbox v6.8.4 seems to use ID3v2.3 too, if such a tag already exists in the track.
If you add a brand new track into Rekordbox v6.8.4, the ID3 standard used (and written back into the track) is v2.4. No APE tags are written into mp3 files.
I could not find a tag called RELEASETIME in my test mp3, written from Rekordbox v6.8.4
These are the current fields (and cover art picture) saved into an mp3 file from Rekordbox v6.8.4:
As you can see from the yellow highlighted entries in Rekordbox
  • Release Date
  • Discnumber
  • DJ Play Count
  • Rating
  • Message
  • Color
will not be saved back in your track.
Also BPM will not be saved into your track.
I don't know how you @djdizzle got RELEASETIME and BPM back into your track 4 years ago.
I could also not find a ORIGALBUM in Rekordbox.
So these are the Mp3tag fields currently filled by Rekordbox v6.8.4:
ALBUM / TALB
ALBUMARTIST / TPE2
ARTIST / TPE1
COMMENT / COMM
COMPOSER / TCOM
GENRE / TCON
INITIALKEY / TKEY
LYRICIST / TEXT
MIXARTIST / TPE4
ORIGARTIST / TOPE
PUBLISHER / TPUB
SUBTITLE / TIT3
TITLE / TIT2
TRACK / TRCK
YEAR / TYER (id3v2.3) & TDRC (id3v2.4)
Little Update:
The Knowledge Base from Pioneer says at March 14, 2023 about "rekordbox metadata":
Some users have asked which metadata fields on their audio files are updated by rekordbox and which are not. The answer depends on what filetype you are using, so here's the list:
In my above own test, I can not confirm that rekordbox update this field:
  • Disc Number TPOS (Mp3tag DISCNUMBER)
The Rekordbox name "Mix Name" TIT3 is called SUBTITLE in Mp3tag.
In this official Pioneer metadata matrix for Rekordbox you can see which fields are only read from existing tags and which are also written back for which music format.
Unfortunately, the matrix was last updated 2019-02-28 and seems to be outdated.
For example Key and Mix Name can be written with Rekordbox v6.8.4.
Others like BPM or Discnumber or Release date are still not updated in the tracks.
