Why are files show up with X and missing bitrate/length
Why am I getting x in front of songs, as you can see it not showing the bitrate or length of the song, yet when I review them in foobar they show up with no issue and can play
Details are usually shown in the Tag File-List column. Can you check the files via MP3 Diags and see if you can repair them with one of the hammer symbols from the top toolbar?
I tried with Foobar2000 as it has a repair functions built into it but even afterwards its still not showing up correctly, but I will try MP3 Diag and see if that makes any difference.
