I am a broadcaster trying to use MP3Tag to write metadata into a Wave Chunk on a WAV file. My objective is to Export an MP3 file metadata and then import the same data to a like named WAV file but using the Wave Chunk metadata. I can export no problem but when converting Text to tag the labels I use don't write to the WAV file Wave Chunk. Specifically DISP, INFO,IALB, INFO,ISRF & INFO,IMED.
