I don't speak German but translate this.
Go to the install directory of your mp3tag and place the files here.
..\Mp3tag\data\sources
Usually you get to the following directory when you type %AppData% in the address bar of Windows Explorer:
C:\Users\YOURUSERNAME\AppData\Roaming
There you should find the subfolder
GERMAN:
Normalerweise gelangst du zu folgendem Verzeichnis, wenn du %AppData% in die Adressleiste von Windows Explorer eingibst:
C:\Benutzer\DEINBENUTZERNAME\AppData\Roaming\
Der relevante Unterordner:
Hi I just wanted to say thanks, I find it extremelly useful.
I'm having a problem with the year and date of some releases, they are not being correctly retrieved from beatport. For example Beatport Release ID 2658839.
Thanks for letting me know. It appears that there's a key new_release_date which is the correct one it seems resulting in the date 2019-08-09.
Is this what you mean?
Can you locally test this for me by editing all the Beatport by &stevehero v6*.inc files and replacing publish_date with new_release_date to see if that solves the issue.
If so, I'll update the scripts.
Welcome to the forum!
Hi! Yes that's what I meant, thanks! Replacing those lines fixed the actual date stored in the ID3 tag, but the date is still different in the intermediate window where all the releases matching the search terms are shown.
Based on your comment, I also tried to change the lines
json_select "new_release_date" # RELEASED
#RegexpReplace "T\d+:\d+:\d+" ""
SayRest
Say "|"
But I only got a blank column.
Leave that section in the [ParserScriptIndex]=... alone.
Keep this as it was:
json_select "release_date" # RELEASED
SayRest
Say "|"
Only touch the code below the [ParserScriptAlbum]=... line.
If you can test this for a while and get back to me. I'll update the scripts then. Thanks for reporting.
Hi!
Thank you stevehero, your work is really appreciated.
When I use the actual "RELEASE Search by (Album)Artist + Release" I never get the Artwork. I always have to do a second search for the Artwork. In a previous version this has been different.
Does this problem also occurs to other uses or did I do something wrong?
Hi Steve!
I've been using the scripts with the "new_release_date" modification for the last two weeks, I think I've tagged around 100 songs and haven't found any more issues with dates so far, so thanks for taking the time to investigate! I guess you can update the scripts now.
Link to release?
I'll update the starting post. Thanks for reporting. Just one of those pesky bugs!!
new_release_date that uses the correct date.Hi Steve!
I found wrong release date in the List of search results for https://www.beatport.com/release/releases/350469
...if I use any "Release search by" option then I can see 2011-03-28. However, release is from 1983.
Of course, script works and I get correct release date after using the script - 1983.
I have seen this several time for some old releases (yrs 2000-2010) before last script update. So it's not new bug and I could say it's not urgent for repairing.
...or link
list of search result 2007-02-05
release page 2007-02-26
or link
list of search result 2017-06-30
release page 2007-07-03
Not sure how to fix this.
For this example, the select_json function is selecting the right one with json_select "release_date"
Beatports json data is wrong.
"available_worldwide":0,
"catalog_number":"732183260062",
"create_date":"2017-10-05T04:25:50",
"encoded_date":"2017-10-04T22:25:50",
"exclusive":0,
"label_manager":"travis kirschbaum",
"publish_date":"2017-06-30T00:00:00",
"release_date":"2017-06-30T00:00:00",
"release_id":2127218,
Hi, first I wanted to thank you for the awesome script, it has helped me a lot fixing my library...
I have one question
Can the columns in the Tag Sources screen be permanently rearranged? I noticed you can drag them but they will reset the next time you do a search.
Thanks!
Sorting is done in line 41 in the file "Beatport by &stevehero v6_Release Search.inc"
[IndexFormat]=% ā EXCLUSIVE%|% ā ID (ā£_ā¢)ā¢%|% ā TRACK COUNT%|% ā RECORD LABEL%|% ā RELEASED%|% ā CATALOG%|% ā RELEASE NAME%|% ā ARTIST/S%|% ā REMIXER/S%|% ā GENRE/S%|%_URL%
You also have to comment out unwanted columns or change their order, beginning in line 75 (json_select "exclusive" # EXCLUSIVE).
Thank you!
I found it,
I want Track Name to be the first followed by % ā ARTIST/S% and % ā RELEASED%
But I don't see Track name there, which one would it be?
Thanks again for the quick reply
In this case it's
"Beatport by &stevehero v6_Track Search.inc" you have to edit.
Got it working!
Thanks again
Finally fixed my code to auto run a Web Source Script from outside Mp3tag. (Sort of like automatic tagging) ![]()
Just thought I'd make people aware it exists.
Beatport Record Label
How can I get the Record Label Tag Field?
When doing the search I can see the field
Example
But on the following screen I can't see Record Label even scrolling all the way to the bottom
is there a way to add this field so it gets updated when doing the tag source search??
Thanks!
Scroll down. It's under publisher.
