[WS] Discogs (pone mod)
The files from the update are for the "export" folder of mp3tag. I wrote that.
As for your cover problem, this isn't possible as far as I know. But there is an option in mp3tag to save covers from Web sources only as picture file and not into the ID tag. That's what I do. After that, I have an action to put the pictures into the files only when there is no cover present in the ID tag.
Yes, I had seen that you wrote that the files are for the export folder. But you also said: "overwrite the existing files" and at least concerning me I didn't have those files and hence couldn't overwrite them. This was the only thing I wanted to mention :wink:
Anyhow, I tried the whole procedure once more and vòila: it worked. Don't know why, I'm quite sure I did the same, but this time it worked. It might not be necessary to restart the computer, is it ? Anyhow, as I said, it's probably my fault and it was :flushed:
... and once more: THANK YOU SO MUCH !! :slight_smile: :music: :slight_smile:
OMG! It's working again!
THANK you so much jokertest for fixing the script.
And thank you also alwayswrming for the easy to follow explanation.
I've been storing MP3's that need editing for so long now... very glad I can finally update the tags :smiley:
You guys rock. And of course still thank you pone for the original script. Wish you had the time to update it but we are grateful nonetheless.
Finally got this working again! After installing Windows 10 from zero, of course! :smiley:
This is SO GOOD and important that it should exist on the application by default!
Is there another bug related to cover art? Worked fine up until last week. Now cant get any images with, or without the pone script :frowning:
Using the latest 2.79 version, and 4.4 update pone
Reauthorized with discogs
No luck..
Yep same problem here for the last couple of weeks I think the images do not appear to be being pulled in, same thing on the previous version and now 2.79. Running latest pone scripts.
Can you try again?
I've noticed that my Discogs image proxy wasn't working as expected and I've just fixed that.
Kind regards
– Florian
Yep perfect! Its working again :slight_smile:
Thanks for all of your effort with Mp3tag it is wicked!
Quick question for anyone though... is it possible to pull in a specific image e.g. the first one rather than than the last image?
Yep, works again! Thanks a lot! :smiley:
I can see cover again! Thank You very very much!
I recently used the Direct by Discogs ID script on an album where a CHAPTER was assigned to a multi song track. The release ID used was 6518000, for The Rocky Horror Picture Show. Discogs tracks B3a, B3b, and B3c are part of chapter "Rose Tint My World". I have these as separate tracks/files.
When I run the script, CHAPTER "Rose Tint My World" is assigned to the three tracks, and it is assigned to the remaining 3 tracks for the album. Discogs does have a "-" after the B3c track, which indicates the end of the chapter. Is the script working correctly? Do I have to create an action group to remove the CHAPTER from the last 3 tracks of the album?
Gary
I've found a few more albums that have multi-song tracks, and the script assigned the chapters correctly to all but one of them. The one that had a problem also had a dash to indicate the end of the chapter in Discogs. This is very easy to fix in the script or after the script. Therefore I feel the script is running correctly.
Gary
I am having some problems with images.
I am using the latest MP3TAG version (2.79) and the latest Discogs script (4.4joker01).
When I try to tag the following Discogs release, the last image will be shown in the 'Adjust tag information' dialog:
https://www.discogs.com/Aztec-Death-Demo/release/8352476
It is not the front cover that is shown on the Discogs page, it is the disc label - the last of the 3 available release images.
Is there still a bug in the script or does anyone knows how to fix it?
And a second (more general) question: in MP3TAG I will only see one image in the cover section in the 'Adjust tag information' dialog. Is there a way to step thru all available images on Discogs. I think some (long) time ago I read something here it is possible, but I have never seen back/forward buttons.
Thanks for your time and any help...
I'm using Mp3tag 2.79 with the latest Pone mod(4.4,joker01)
I've had no problems using web source script Direct by Discogs ID for the past couple of weeks, but today I encountered a problem with one Discogs release. Today I've used Direct by Discogs ID for other release IDs prior to and after the problem without any issues.
The problem occurs with Discogs release ID 721701, Pink Floyd, The Final Cut, 1983, CK 38243. I receive message "Sorry, no entries are matching your search criteria". I have the release in my Discogs collection, so I know it is a valid release ID.
Thanks for any help you can provide.
Hi Gary,
i can verifier this issue with this ID721701 only and i guess some with Discogs Website. ist only working if you use search by lable and catalog like cbs&catno=CK 38243
@others
yes sometimes you will get not the right Image and ist not a bug in pone script.
For me i use album art downloader because discogs Image have max size 600x600 and thats to small for me. it work perfect with MP3Tag together. Check out in this Forum.
Jokertest,
I'm sorry to report that I get the same message when I search with label and catalog using cbs&catno=CK 38243. Previously I tried Search by Album(Artist) + Title and that also gave the same message.
Today I tried the Tag Source discogs that I believe is a default with Mp3tag. When I click on Tag Sources, it is the entry below Cover Art. It has the album title, I click Next, and have a list of albums. I select the one with the correct year, 1983, format, CD, and company, CBS. There are two in the list, and the second one is for release ID 721701. I click next and the script is able to retrieve information from discogs for release ID 721701. Maybe this script works because it doesn't retrieve as much information from discogs as the pone scripts do. I'll probably use this script and manually add/modify tag information for this album.
Thanks for looking into it.
Gary
Help with discogs Pone oauth failure. I'm using 2.80c of MP3tag.
I've just installed this for the first time today having previously used the standard discogs function. I've done the install into the %appdata\mp3tag\ directory, run both of the action steps, update settings and create scripts.
The first Oauth failure I logged into my discogs account and removed mp3tag. Went through re-authorizing mp3tag and the standr discogs works but I get an oauth 403 failure with either the extended scripts or the discogs Pone scripts.
I'm sure its my mistake, but I'm at a loss. Help?
If I'm understanding your post correctly, I think I'm getting a similar error. The error I receive is "Error connecting to server: www.discogs.com >> 401 unauthorized". I'm a very new user of MP3Tag and discogs, but near as I can tell, I followed all of the steps in the top post exactly. :unsure:
No, this is not the same problem. I'm getting 403 authorization errors using additional scripts with discogs from mp3tag. The base discogs tagging function found under tag sources works fine.
In order to use the built-in support, when you first use it, you will be directed to discogs to log-in with your discogs ID/Password and copy an API key to mp3tag. If you've done that and are using the base discogs function in mp3tag, then I'm not sure how to help. I'm just a user though, not an expert.
Anyone? I have not been able to get the authorization to work, yet it works fine withy the built-in discogs function. I'm sure I'm doing something wrong but would appreciate a pointer...
