same problem here buddy, using the latest version. im quite certain there is no error on my part. it is either a problem with the script or discogs.
Can I run these scripts as a batch, rather than one song at a time? Billiant work, can finally get Genre.
@MarkC I've been using the Discogs Pone> Direct by Discogs ID script for the past three weeks without any problems. Are you sure you are using the latest versions of the scripts? The last time we had 403 errors the changes to fix the problem were outlined on page 53 of this thread around reply #781.
Hopefully that will help you.
Gary
mp3tag - v2.80
pone - 4.4 Update 1
Everything works fine, except for certain search criteria which results in a 401: UNAUATHORIZED.
I have followed all previous steps with regards to [OAuth] etc.
For example, perform a standard search for the following.
P.O.S. Gravity (Original Mix) = 401
P.O.S. Gravity = 401
P.O.S. = 401
POS = No 401, but not finding relavent results.
The discogs ID that I am trying to get a result for is : 363202
Essentialy, whenever there is a period (.) (hex code 2e) in the search query, my search will fail. Maybe this is an issue some others are reporting with 401's, not realising the period in the search query is giving them this error.
PS. Awsome script.
PPS. Would be cool if there was an option to specify the Genre seperator in the .mp3 settings file - ie pone gives 'House\\Trance\\Techno' - i Prefer 'House / Trance / Techno'
I did manually do this for anyone interested, with the following code change (but would be nice as a settings option)
#< ## GENRE #
outputto "GENRE"
findinline "\"genres\":" 1 1
sayregexp "(?<=\")[^,].+?(?=\")" " \\\\u002f " "],"
gotochar 1#>
JmmyBoy
I'm using Mp3tag V2.80 with pone 4.4(joker01 update). When I use Direct by Discogs ID with Discogs ID 363202, I don't get any errors and get the Discogs information. I don't know if you've only tried the standard search or if you have tried other searches. When I know the Discogs release ID, I always use the Direct by Discogs ID search.
Gary
I noticed that most of the composer/written by tags don't load to the tag filed "composer" although I set it to do it as extra fields. For some reason one to three show up, the rest looks like it hasn't been pulled from discogs. Any suggestions?
Hi Gary,
Searching by Discogs ID works fine for me, I was just giving that as a reference to the release I was referring to.
The point I was trying to make is a discogs Standard Search with "P.O.S. Gravity" will result in a 401, searching for "POS Gravity" will not result in a 401, but does not display any relavent results. Essentially, I find that when the search string contains a period (.) the search will fail with a 401.
Thanks
Any way to combine each set of the tracks below of disc two in this release?
See CD2: https://www.discogs.com/Stephan-Bodzin-vs-M...release/2760764
Such as combining:
a, b & c of 2.5
a & b of 2.7
a & b of 2.12
The tracks are:
2.5a Callisto
2.5b Callisto (Joris Voorn Remix)
2.5c Callisto (Dominik Eulberg Remix)
2.7a Phobos (Pan-Pot Remix)
2.7b Phobos (Synthapella)
2.12a The Alchemist
2.12b The Alchemist (Robag's Kopakkmuuf-Rekksmo)
Hello everybody,
Does anyone have any Discogs script that does the search by artist name and music? I'm trying to adapt what I have here, but it's complicated and I'm running out of time.
Thanks all!
In UPDATE (v2.7) a new tag field called CHAPTER was introduced.
The chapters or disc names found as headlines above or between the tracklist at discogs.
Look at this pages for examples:
http://www.discogs.com/Joy-Division--Singl...release/2586049
http://www.discogs.com/Kraftwerk-Der-Katalog/release/1996371
http://www.discogs.com/Erykah-Badu-Mamas-G.../release/424341
It works fine but I don't understand how to make use of it or which software makes use of it.
I can't get it to work in Logitech Media Server / Slimserver?
Is there a way?
Kind Regards
Johan
Hi Johan,
here some basic information about chapter mark:
http://id3v2-chap-tool.sourceforge.net/
https://auphonic.com/blog/2013/07/03/chapte...anced-podcasts/
most player out there can not handle chapter. you need a player where you can add custom library field and maybe it work.
for me I use JRiver https://www.jriver.com/
and I add this field in my library. check out the uploaded pic.
JRiver is not for free but for me the best player out there coz I have a hug collection and no other player can handle my few mp3
. this player have some more cool features
regards jokertest
For the love of god, can anyone help me out? I'm trying to assign the track number in multidisc releases to the track field, and disc number to the discnumber field, easy as that.
I only get combinations of track+discnumber in the TRACK tag, e.g. track 1.1
I would like track 1.1 to have 01 as TRACK and 1 as disc number.
I'm guessing it has something to do with the track positions as mentioned on Discogs.
Is there any way I can tell the script that track position 1.1 (or 1-1 for that matter) means "discnumber.track" (or discnumber-track)?
UPDATE: just found out!
I had to remove "TRACK" in the line below.
Trackposition (as written on discogs page): >TRACK
- write Trackposition only for Vinyl & Cassettes >no
+1 on this!
Search?
/t/17761/1
[WS] Discogs (pone mod)
Hello
Respect for the excellent script.
I have some questions to configure.
At the beginning of:
How to disable save in tags: artist, album and titles.
Part of the music is well tagged and I just want to upgrade with additional information from the discogs.
Format settings - Format (complete) -
In the list of results shows: ... Vinyl, LP, Remastered, Compilation
And writes to the tags: ......... 2 x Vinyl, LP,, "Compilation", Remastered,, "Compilation", Compilation,, 180g, ...... (I prefer the version from the list of results) -
How to set Releasetype (eg Album, Compilation) and Releasestatus (eg Official, Unofficial Release)
Greeting
Zwanzig
EDIT:
2 and 3 SOLVED
Hi, do you plan on publishing it on github?
Another question: can you make a tutorial to explain how we can fect info from a release ID?
I really don't understand the explanations you give in the first post...
Thanks
No tutorial, sorry. I started something like that several times. To messy for me,too.
In the settings file, you can leave every place for tag field names empty. These tag fields are not written at all.
In your case, at "ARTIST NAMES":
Artist - Primary Name: >
Artist - Name Variation: >
and at "OTHER FIELDS & OPTIONS":
Album: >
Title: >
