Hi All, my first public release of an MP3TAG Web Source Script.
Following revisions to the IMDB web site, I found my original scripts I used from here were failing, so I have revised them to work with the new site layout.
I have some avi files i would like to tag, but as far as i understand ID-tagging is not possible with avi. And Mp3Tag does not avi files at all.
I was already thinking about storeing some 1 second dummy mp3s in every movie folder and tag it with a script like yours just to have a reference file to find the movies.
Is there any other possibility?
I only use mp4 files at present as I stream my DVD collection to a PS3 using Twonky media server running on a NAS box. Will switch to MKV once PS3 supports them being streamed!
Started out with AVI but soon changed because you cannot tag AVI or at least most software won't read AVI tags.
You could use the my movies program which you can set to store an XML file with all the info in
it will do it automaticaly for you
pone, does abcAVI Tagger do what you seek? Althou I've never had success importing from imDB. (Not that we wouldn't want MP3Tag to fulfill all A/V needs. )
I always have problems with the Divx codec on my primary PC so I don't intentionally have any around but I tend to collect programs that might serve a future need - I love metadata - and IMDBScanner (http://www.dancemammal.com/moviedb.htm) was so queued. There are you who are more serious about coding than I so perhaps it's something that others might care to pursue since the download includes the Delphi 6 source code. I think its developer's tag is just a appropriated MP3 tag.
Looks like I do have some with Xvid so I've installed and will try. Looks good but my security protocols may be blocking it working so ... I need to futz and report back.
Is there any current development for an IMDB source scrip? I have tried many of them posted, and they either do not work at all or don't get the information I am looking for. I want genre and nothing seems to do it.
I've finished updating the script. It's hacky, as it now uses IMDB's json search to build the index but does not use MP3Tag's json-specific parsing commands as I can't be bothered figuring it out. It just does the regular string searchs and movechars.
I actually gave it the briefest of attempts but I kept getting weird 404 errors in MP3Tag with JSON enabled so I shelved it for the time being. I just wanted a quick solution lol.
That XML code has been there for years, and I believe it's required for that itunes field so it can be recognized by appletv etc. I can't remember why and I have no idea if it's still needed, so I left it alone.
