[WS] iTunes
Try this (just some of my modifications to the script I use personally):
# PUBLISHER
    outputto "PUBLISHER"
    regexpreplace "\,\s[Uu]nder\s[Ee]xclusive\s[Ll]icense.*?(\",)" "$1"
    regexpreplace "(?:(?<=\"copyright\":\")(?:[^A-Za-z0-9]\s)?\d{4}\s([^/]*).*?(\",))" "$1$2"
    sayregexp "(?<=\"copyright\":\").+?(?=\")" ", " "}"
QUOTE (ms6676749 @ Jun 18 2017, 02:45) <{POST_SNAPBACK}>
# PUBLISHER
    sayregexp "(?<=\"copyright\":\").+?(?=\")" ", " "}"<!--QuoteEnd--></div><!--QuoteEEnd-->
Thanks so much again, its working perfectly. learning from what you gave me I added a line to remove ", a division of" clauses that come up alone sometimes; example- Epic Records, A Division of Sony.... you can see how i added below. It's amazing how helpful you guys are on this forum
regexpreplace "\,\s[Aa]\s[Dd]ivision.*?(\",)" "$1"
regexpreplace "(?:frowning:?<=\"copyright\":\")(?:[^A-Za-z0-9]\s)?\d{4}\s([^/]*).*?(\",))" "$1$2"
I am curious about the indentation of some lines though, is this just for organization or does mp3tag actually read the indented lines differently? my script seems to be working fine without the indentation
has anyone changed this window to automatically prompt "No" instead of "Yes" to increase workflow speed? I've tried to find this window in Resource Hacker but haven't been able to
If you press Alt-N on the keyboard (or perhaps even only "N") you can close the window almost as easy as pressing enter.
Also, there are some options in Tools>Option>Messages where you can tune which messages you want to see.
Organization. It is easier for me to find stuff I need to edit that way.
works great thanks a million
ah makes sense.
Ok this is likely my last question so I can finally stop bothering you guys. Regarding the [IndexUrl] and [AlbumUrl], I want the script to search a different index by the track name not the album name, so that when entering my SearchBy prompt of "%artist% %title%" the result will come up with the album containing that track even if the %title% isn't present in the album name.
I've tried some combinations of entity=musicTRACK and adding some attributes but no combinations i've used have gotten results so I'm wondering if i could get some help here as well. Thank you again
Error script!
https://itunes.apple.com/de/album/till-i-di...ts/id1250936060
If there's an error, please post the last line of %AppData%\Mp3tag\data\scripterror.log here together with the name of the source used.
scripterror.log empty
error only this album, others o.k.
Is there a way to search by title (track name) and derive the album name from the list.
see this post:
[WS] iTunes
Thank you very much!
Thanks for your job.
But I have some question.
First. There is multiple disc album.
When disc 1 have 15 track, script makes Disc 2 starting tracknumber 16, not tracknumber 01.
Can I fix it?
Second. Year Tag, likes 2016-03-02T08:00:00Z.
But I want use '2016-03-02'
I looked method of '2016' in this artcle, but '2016-03-02' coudn't find.
First: after loading the data from the web source, do some post-processing.
Renumber the tracks with the tracknumbering wizard.
Second: YEAR should only contain 4 digits.
The fomat you mention is suitable for RELEASETIME.
To cut the left four digits use an action of the type "Format value" for YEAR,
Format string: $left(%year%,4)
You can get ultra hi-res artworks at 1500*1500px with this:
sayregexp "(?<=\"artworkUrl100\":\").+?(?=\")" ", " "}"
regexpreplace "100x100bb" "10000x10000-999"
outputto "COVERURL"
Full Script for US iTunes website only. Change this a per threads recommendations for other countries.
i_Tunes__US__stevehero_Edit___Artwork_.src (3.8 KB)
This might have been done by someone but a quick thread search yielded no results. :slight_smile:
Nice job, i'm happy to see that the script's still working :wink:
not working for me
Hello,
I have a problem with the script for a few days, I would like to know how to solve it.
mp3tag%20error
Thanks
Is there anyone else with that error? You know how to fix it?
Yes. If you try the url with your browser it's working.
